  Bogging and shifting early
Bogging and shifting early by fierokid88
Started on: 12-02-2025 08:47 AM
Replies: 9 (99 views)
Last post by: fieroguru on 12-03-2025 01:43 PM
fierokid88
Report this Post12-02-2025 08:47 AM Click Here to See the Profile for fierokid88Send a Private Message to fierokid88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, back in august i bought my 88 fiero formula not running. Put a fuel pump in and the car fired right up and drove amazing. Yes it still had issues like high idle. I’ve fixed all the little problems over the months. I now have a bog after driving 800ft and the car shifts super early.
Here’s a list of what i’ve done. I’m lost at this point. Any sensors or parts that weren’t replaced tested good.
Fuel pump (has adequate fuel pressure while driving… 43psi)
Injectors
IAT
IAC
MAP
Smoke tested (fixed all leaks including EGR tube)
EGR delete
has no catalytic converter
CTS (ECM sensor)
All grounds
No codes on ECM
O2 sensor
Coil is in spec
Pickup coil is in spec
New timing chain and gears (ignition timing reset after)
Any help is much appreciated!
Report this Post12-02-2025 11:09 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has the transmission fluid and filter been changed?
Report this Post12-02-2025 03:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
With ALDL jumper in place?
fierokid88
Report this Post12-02-2025 05:44 PM Click Here to See the Profile for fierokid88Send a Private Message to fierokid88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Followed everything via service manual
Report this Post12-02-2025 05:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I now have a bog after driving 800ft...
800 feet? Is that a typo?
fierokid88
Report this Post12-02-2025 08:36 PM Click Here to See the Profile for fierokid88Send a Private Message to fierokid88Edit/Delete MessageReply w/QuoteDirect Link to This Post
No unfortunately. It revs great in park. In drive, it will shift early, then after about 800ft it will just fall flat on its face and won’t move past idle speed without bog. Super confused as i’ve done everything i can with the car.
I can’t even get it 3 miles to my shop to get it on the lift!
fierokid88
Report this Post12-02-2025 08:37 PM Click Here to See the Profile for fierokid88Send a Private Message to fierokid88Edit/Delete MessageReply w/QuoteDirect Link to This Post
fierokid88
Member since Aug 2025
No, it’s something i should definitely do. Fluid is old and losing its color. Doesn’t smell bad though.
Report this Post12-02-2025 08:44 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a TV cable adjustment issue.
Also could try disconnecting the TCC connector. It might be locking up the converter when it should not be due to a bad pressure switch.
fierokid88
Report this Post12-03-2025 08:08 AM Click Here to See the Profile for fierokid88Send a Private Message to fierokid88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still does it unfortunately.
Report this Post12-03-2025 01:43 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It might be time to verify the timing mark on the balancer. It is know to move, so you could have set the timing correctly to an improperly positioned timing mark.
Of just add 10 degrees advance and take it for a spin to see if there is any difference. If not, put it back. It there is, then check the mark.
