  Headlight not coming up properly
Headlight not coming up properly by jon m
Started on: 12-01-2025 12:24 PM
Replies: 9 (119 views)
Last post by: 1985 Fiero GT on 12-03-2025 02:09 PM
jon m
Report this Post12-01-2025 12:24 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi - Here's the background to my issue which has happened to other members on here many moons ago.
around 2014 - I rebuilt the headlight motor using Rodney's Kit - (like all of his stuff it is top notch) and worked fine
The car was driven mostly during the day and occasionally at night.
What I am experiencing is that the Driver's side light seems as though it retracts too much because sometimes it doesn't go up after a period of time however if I turn the knob on the top of the motor it will lift and springs back into action.
I am pretty sure it is not an electrical issue.
Many thanks for any advice given
Jon
Mickey_Moose
Total ratings: 145
Report this Post12-01-2025 01:12 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Helps if you post the year of your car as there are 2 types of motors.
Could be a limit switch issue if 1st Gen (84-86)
[This message has been edited by Mickey_Moose (edited 12-01-2025).]
jon m
Report this Post12-01-2025 01:44 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point @Mickey Moose
1987 GT I believe it was built in May of that year.
Jon
[This message has been edited by jon m (edited 12-01-2025).]
Vintage-Nut
Report this Post12-01-2025 02:26 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the Gen 2 / '87-'88 system, the headlight SWITCH and the motors are the top issues...
jon m
Report this Post12-01-2025 07:01 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Vintage-Nut - in the way I describe ?
Jon
Total ratings: 200
Report this Post12-01-2025 10:22 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Jon
When you say you rebuilt it, you replaced the three white plastic bushings?
This video might also help:
Vintage-Nut
Report this Post12-02-2025 12:44 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Gen 2 system has three main components: the headlight switch, the control module under the left fender, and the headlight motors.
Members had reported that the headlight switch or the motors were their solutions; failed modules are rare.
Some were able to repair the motor; others brought new or remanufactured motors instead.
Fiero Gen 2 Headlight Motor Rebuild starts at the 5:00 minute mark...
https://youtu.be/XEbRMW57bF0
Gen 2 Headlight Schematic also may help you to troubleshoot the issue:
jon m
Report this Post12-03-2025 01:42 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes - did the 3 plastic bushings with Rodney's Kit.
Jon
jon m
Report this Post12-03-2025 01:45 PM Click Here to See the Profile for jon mSend a Private Message to jon mEdit/Delete MessageReply w/QuoteDirect Link to This Post
jon m
Member since Apr 2004
Thank you for the Link Vintage-Nut - I think I will take out the light and go over the motor to double check that I haven't missed anything the first time around - the Passenger side is running perfect since I did it 3 or 4 years ago.
Jon
[This message has been edited by jon m (edited 12-03-2025).]
1985 Fiero GT
Report this Post12-03-2025 02:09 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jon
The way you described is a common thing with the limit switches in gen 1, although I would probably think that a brush is loose or broken in the gen 2 motor (my gen 1 headlights were both non functional when I got my Fiero, but on the drive home, one headlight decided to pop itself back down, upon rebuild, both headlights had broken/missing/loose brushes in the motor, whatever movement happened when driving brought it in contact enough to go down. Sometimes moving the knob would make it "catch" a little bit, but that was extremely unreliable.)
