  weird washer is broken for screw decklids
weird washer is broken for screw decklids by Carlin
Started on: 11-03-2025 06:52 PM
Replies: 8 (125 views)
Last post by: Vintage-Nut on 11-04-2025 05:56 PM
Carlin
Report this Post11-03-2025 06:52 PM Click Here to See the Profile for CarlinSend a Private Message to CarlinEdit/Delete MessageReply w/QuoteDirect Link to This Post
so I got me some decklids. I no longer have 2 massive holes in my trunk. so on the decklids are 2 screws and under them is this small plastic washer that keeps it on the decklid. mine cracked so now it just falls off. I went to napa, bombgars, and ace. nobody has this oddball size. I sent a photo of it so you guys know what I'm talking about.
Report this Post11-03-2025 07:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
All those washers do is keep the bolts attached to the grills upon the grills removal from the engine bay. The washers aren't critical to holding the grills in place.
Carlin
Report this Post11-03-2025 07:59 PM Click Here to See the Profile for CarlinSend a Private Message to CarlinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I still want to replace it though so the screws stay on.
[This message has been edited by Carlin (edited 11-03-2025).]
Vintage-Nut
Report this Post11-03-2025 08:19 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store
Decklid Vent Screws w/ Washers / Part # 60525
https://www.fierostore.com/.../Detail.aspx?s=60525
Carlin
Report this Post11-03-2025 10:32 PM Click Here to See the Profile for CarlinSend a Private Message to CarlinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Vintage-Nut:
The Fiero Store
bro thank you. they are expensive but I'll buy them on my next pay check. btw the other deck lid has flat head screws for some reason so I'm going to swap those out so both deck lids match
and I have one more question. so on the top of the deck lid is a rubber seal that goes against the window. one of them is missing it. is it possible to buy a new seal and reattach it.
Vintage-Nut
Report this Post11-03-2025 11:55 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The key is IF you can find the shape of the seal.
PS - On my GT, the J-seals were pop riveted on the grill/vent
[This message has been edited by Vintage-Nut (edited 11-04-2025).]
Carlin
Report this Post11-04-2025 02:42 PM Click Here to See the Profile for CarlinSend a Private Message to CarlinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I feel like making one wouldn't be to hard. just need to buy silicone or rubber then shape it. I may try to fix it later on. btw I bought 4 washers and 2 of the screws on the Fiero store. it cost me 30 dollars. so expensive for such small parts.
Report this Post11-04-2025 03:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...which is why I thought I'd bring it to your attention in my first response that those washers aren't required to hold the grills in place.
And by the way, the two types of screws/bolts on the grills are the way Fieros came from the factory. The "flat head screws" go on the driver side grill, the flip-up screws go on the passenger side grill... probably to give easier/quicker access to the battery.
Vintage-Nut
Report this Post11-04-2025 05:56 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Because you only brought one item.....the kit costs $17 plus tax and shipping.
To me, I never buy 'one item' from TFS or any other auto store; I make a list and one day, I order the list.
My last TFS order had two big items and around a dozen of little parts, like the kit you brought.
I checked the shipping cost on the big items separately first, then together. The shipping cost was 'cheaper together' than separately.
PLUS, all the little parts didn't change the shipping cost, so these little parts had 'free shipping'.
So, if you want to buy the correct parts than 'skipping it' - made a list until you have enough to order.
My two cents...
