  125c Transmission Rebuild (1st time, all stock)
125c Transmission Rebuild (1st time, all stock) by Cunnive
Started on: 11-03-2025 04:35 PM
Replies: 4 (83 views)
Last post by: Dennis LaGrua on 11-05-2025 11:13 AM
Cunnive
Report this Post11-03-2025 04:35 PM Click Here to See the Profile for CunniveSend a Private Message to CunniveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all!
I have an 86 2.8L V6 SE (about 60k miles on it) and I've decided to go down the road of rebuilding my first transmission. I'm not doing anything fancy, everything is stock. However, let me give you a little background.
When I removed and tore down the engine a couple years ago, I was planning on going down the road of a 4T60 swap but now I decided to rebuild the tranny instead to save time & money. Over the years, the 125C transmission and torque converter have been sitting in my garage collecting dust and suffering from north carolina humidity and now that I am prepping to rebuild the transmission, I have some questions and was hoping yall can give me some guidance too for a first timer.
Here is what I purchased in preparation for the rebuild.
-TH125 Rebuild Kit 125C 3T40 TH125C Automatic Transmission Transaxle Master Overhaul Banner Box Set
-Superior GM TH125 TH-125 TH125C TH-125C Automatic Transmission Shift Correction Kit
-TH125C ATSG Tech Rebuild Service Manual
Here are my questions
-Is there anything else I should purchase here?
-Looking at the torque converter and flex plate, how do I clean this up and reuse it? Should I even reuse it?
-What should I do with the flexplate? Does this simply need a cleaning / resurfacing or should I buy a replacement from the Fiero Store website?
-Regarding bolts for the parts inside the transmission, should I reuse these or is it recommended to get all replacements?
Thank you all!
[This message has been edited by Cunnive (edited 11-03-2025).]
Report this Post11-03-2025 05:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would recommend purchasing the rebuild manual for that transmission. Would also recommend taking pictures at every stage of disassembly. It is usually standard procedure to replace the torque converter as well. If you want firmer shifts and eliminate slippage I would recommend the transgo shift kit.
The key is to take your time and ensure putting back all parts in the exact same order that they were disconnected. When reassembling the valve body the valve balls must be in the exact same place that they were removed from.
Cunnive
Report this Post11-05-2025 09:32 AM Click Here to See the Profile for CunniveSend a Private Message to CunniveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dennis!
Is there anything I should look for in regards to the gears and other components I remove from the transmission that are common failure points?
If a particular gear is in bad shape that should be replaced, can these be purchased from an online store? How would I go about this sitation?
What lube should I use when reassembling? Can I use assembly lube or is there other more specialized lube?
Should I also buy the Auto Lock-Up Solenoid and Auto Trans Pressure Switch from the Fiero Store?
Thank you!
[This message has been edited by Cunnive (edited 11-05-2025).]
Vintage-Nut
Report this Post11-05-2025 10:34 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Automatic Transmission Rebuild (1st Time)
IMHO
I'm a 'do it yourself' guy too; however, somethings need more knowledge, specialized skills or tools and experience that I don't have...
On these special occasions, like rebuilding cylinder heads, I give them to a shop rather ducking it up!
Due to the complexity, rebuilding an automatic transmission might be over your head.
“Look Before You Leap”
When examining automatic transmissions, one must consider the complex network of hydraulic systems and electronic controls that enhance driving convenience. An automatic transmission rebuild requires a thorough understanding of these intricate mechanisms.
Complexity:
Automatic transmissions are more complex and contain multiple components, such as valves, clutches, and electronic solenoids, which require specialized knowledge for proper rebuilding.
Inspection:
When rebuilding automatic transmissions, a thorough inspection of hydraulic systems and electronic components is necessary.
Adjustments:
Automatic transmissions require calibration of the shifting points and pressures.
Good luck and the best on your effort,
VN
Report this Post11-05-2025 11:13 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've rebuilt automatic transmissions and it is an intense and careful procedure that must be followed. Its just a lot of parts that need to be removed and replaced. That is why I recommend taking pictures every step of the way. It was a 4T60 and I went by the rebuild manual and the rebuild video that was available. A few special tools are needed but you can make them. You Tube has some rebuild videos.
TH125 tear down
[This message has been edited by Dennis LaGrua (edited 11-05-2025).]
