  Interstate Batteries for 2.8 Fiero
Interstate Batteries for 2.8 Fiero by Carlin
Started on: 10-31-2025 01:41 PM
Replies: 11 (179 views)
Last post by: Patrick on 11-07-2025 01:03 AM
Carlin
Report this Post10-31-2025 01:41 PM Click Here to See the Profile for CarlinSend a Private Message to CarlinEdit/Delete MessageReply w/QuoteDirect Link to This Post
need help finding a good interstate battery for my car. There's a few options on the website but I don't know what I should get.
here's a link, I already have the model set up in the website
https://www.interstatebatte...-pontiac-fiero-v628l
Report this Post11-01-2025 09:02 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
They will all fit.
What fits your budget?
Report this Post11-02-2025 03:19 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO the quality of all new replacement car batteries has gone way down. I purchased my Chrysler new in 2020 and the original battery is still going strong. When I purchase new batteries they last less time. Come replacement time I'll just bite the bullet and buy a DEKA AGM battery, Those have been proven to last a long time.
Unbeknownst to most there are only two large domestic battery manufacturers that make 95% of the brands In the USA.. They are Johnson controls and Exide.
Stingray92
Report this Post11-02-2025 08:46 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I hope I just had bad luck on a Deka AGM 95R. It was only in service less than 3 years somehow the wife or kid was able to drain the battery to 4 volts, I was able to revive it but this is like the 4th or 5th time I've had to do this. Tested with a battery tester and it's coming out weak
I have 3 other Deka's, 1 in my ride 5 years albeit still puttingit back together, the others are over 10+ years old. East-Penn does quite a bit for lead recycling, not sure about Jonhson Controls or Exide. I miss the green eye Delco's, kind of predictable but reliable.
Stingray
Report this Post11-02-2025 10:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Automotive batteries that are drawn down to a low voltage can suffer from sulfation. They can usually be restored to like new condition with a battery desulfator. I have successfully restored some automotive batteries this way
Vintage-Nut
Report this Post11-03-2025 09:06 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The clock or other parasitic battery drains can kill the battery - keep the battery fully charged or disconnect the negative cable.
In average, my batteries last 8 to 10 years...
As 'Interstate Batteries', I chose at my local auto shop who carries batteries known for their long service life...
I try to buy the highest cold cranking amps (CCA) batteries I can.
On the Fiero, I changed to top posts and side posts as I 'hate' the negative side post location..
Stingray92
Report this Post11-03-2025 09:25 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll report back the outcome of attempting to save this battery. It was @ 12.3 volts yesterday afternoon, tonight 11.7. Yes I might have some other gremlin lurking on the car.
Dennis thanks for the tickler about de-sulfication, quite likely what my battery has going on.
I found this little charger that can do more than my older charger, technology has changed and hopefully this pans out.
As far as exide, Johnson Controls, East Penn I would do East Penn, Exide, then Johnson. Just my 2 cents
[This message has been edited by Stingray92 (edited 11-03-2025).]
Stingray92
Report this Post11-04-2025 10:50 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok,
So i let the battery charge overnight, never did get the solid green light of full charge. I did the repair function this evening it took a little over 3 hours and when I tested it was pleased, the result is now good.
I'll see how it goes, hopefully this was just a one off.
Stingray92
Report this Post11-05-2025 09:20 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Short update reinstalled the Deka last night 12.5 volts, car started perfectly.
On a hunch I checked the voltage thus evening and it was down to 12.05. I'm not sure why it dropped so much, my other Deka right at 12.5 and it's 4 years old.
I'll test it again in the morning. For what it's worth I did check for battery drain, this car is at .3 amps. That seems well in range for a idle/shut off vehicle.
Report this Post11-05-2025 10:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it? It was stated in This thread that it should be more like 15mA - 25mA. You're at 300mA.
Stingray92
Report this Post11-06-2025 09:59 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed 300 ma is a lot, I should have prefaced the car the battery I'm refrencing is in is a 2016 Hyundai Genesis.
The voltage of the battery this morning was 11.8, this evening was 11.9. Car started on its own power and I let it run for 30 minutes ~. Afterwards I checked the voltage waiting about 15 and it was at 12.2 (14.4 w/engine running).
Redid the drain test and it held steady at .255, I agree this seems high but I don't know what the baseline should be for this car but it has a bunch more circuits than our Fieros.
Anyway I would likely still go Deka depending on price/experience.
Report this Post11-07-2025 01:03 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Even so, how many of those circuits should be active while your Genesis is not running? I'm guessing your battery drain is too high, but I certainly don't know for sure.
