I'm hoping Cold Hose can set me up with the EZ Clip system that uses smaller OD hoses. I'll have to buy the proper pliers. Hopefully, they have a manifold block that will fit the FourSeasons PN 58255 AND allow the use of the popular EZ Clip fittings.
Otherwise, I'm stuck with the hydraulic crimp method.
It's really tight behind the Hooker manifold with the compressor installed.
88GT 355 CI, AED HO 750 Double Pumper, AFR milled 180, Dyno'd at 427 HP, 360 WHP, F40 6-Spd
anderson@gdsconsulting.com
