  Injectors power 85 gt manual
Injectors power 85 gt manual by Miel
Started on: 10-26-2025 06:18 PM
Replies: 3 (33 views)
Last post by: Patrick on 10-26-2025 07:23 PM
Miel
Report this Post10-26-2025 06:18 PM Click Here to See the Profile for MielSend a Private Message to MielEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, looking for advise. I have been rebuilding my Fiero over the last few years. Fiirst redid the whole front end (suspension, cooling, brakes). Then stripped and repainted the body. Finally removed the engine and replaced the head gasket and checked the cylinders and cleaned it up. Also did the rear suspension and cleaned up the cradle and put all new bushings in. However after installing the engine again I cannot get it started. The wiring harness is kind of a mess and at first I thought that it was because the fuel pump wasn’t getting power which it wasn’t but resolved that and now I don’t think the injectors are working. I don’t have a scope so I cannot see the ground closing and opening. Is there a good procedure to test and diagnose the electrical system for the injectors? I tried with the wiring diagram but find it is really incomplete. Is there a more complete version out there?
Report this Post10-26-2025 06:42 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Factory Service Manual has complete.diagrams.
Are all six injectors getting 12v power with KEY ON?
Vintage-Nut
Report this Post10-26-2025 07:22 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check the fuel pressure?
Try Reading *This* Version
https://fieroinfo.com/manua..._and_Drivability.pdf
[This message has been edited by Vintage-Nut (edited 10-26-2025).]
Report this Post10-26-2025 07:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the two injector fuses for continuity. (Don't just do a visual check.)
