  engine swap
engine swap by michael jatcko
Started on: 10-24-2025 03:36 PM
Replies: 3 (104 views)
Last post by: Dennis LaGrua on 10-25-2025 10:02 AM
michael jatcko
Report this Post10-24-2025 03:36 PM Click Here to See the Profile for michael jatckoSend a Private Message to michael jatckoEdit/Delete MessageReply w/QuoteDirect Link to This Post
how hard is it to install pontiac 3800 in fiero or is there a easy bigger motor to use? what is it
Total ratings: 200
Report this Post10-24-2025 05:15 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800 is a very common motor that people were installing, but honestly, there's a lot of newer motors now that might be a better option. If you have a 3800 already, and that's what you want to go with, it's a pretty solid motor. Lots of kits available for it. But if you're scouting for a motor... it might be worthwhile to look at an LNF 2.0 Turbo, or something else.
Report this Post10-24-2025 05:21 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Degree of difficulty depends entirely on your mechanical skillset, availability of needed tools and pocketbook.
Engine swaps are not typically "bolt in" operations.
Report this Post10-25-2025 10:02 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800 engine with the 4T65eHD is one of the more basic swaps, but you will need new mounts, run a belt modification, construct new axles, modify the exhaust system, transmission linkage, water lines, fuel lines, fuel pump and wire it up for a new combined harness. In many cases this will be swapping an engine 25 years old and low mileage engines would be quite hard to find.
