  Heater blows cold in Vent Position
Heater blows cold in Vent Position by 88Fingers
Started on: 10-24-2025 08:51 AM
Replies: 9 (95 views)
Last post by: 88Fingers on 10-25-2025 06:46 AM
88Fingers
Report this Post10-24-2025 08:51 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello guys and gals of Pennocks. 88 GT here in a very cool Ontario Canada and my heater will blow hot in Defrost and Heater positions but Vent blows only cold air! Any suggestions would be great thank you. Non AC car BTW
[This message has been edited by 88Fingers (edited 10-24-2025).]
Vintage-Nut
Report this Post10-24-2025 09:10 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
HEATER / DEFROSTER modes can be tempered
VENT mode cannot be tempered, and it will be 'ambient'.
Total ratings: 200
Report this Post10-24-2025 09:17 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, I guess that makes sense, as it's literally supposed to just be "the vent to the outside."
I've never seen the control panel for a non-AC Fiero, but I know they had special vents that were controlled by buttons under the dash. I have one of those kits, but haven't installed it in my car yet. I think that option (?) was only available on the 84, but of course, you could get cars after 84 without A/C, they just didn't have that feature.
88Fingers
Report this Post10-24-2025 09:32 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, okay so it is normal then? Thank you very much for the quick responses guys!
Vintage-Nut
Report this Post10-24-2025 09:36 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW - the slider-type control panel for a non-AC Fiero CAN be 'midway' to 'blend' the heater and the vent modes:
By varying the mode selector between HEATER and VENT, you can vary the proportion of the air coming out the heater and the vent outlets.
88Fingers
Report this Post10-24-2025 10:30 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Vintage-Nut. There seems to be some resistance to movement in the sliders and wondered what the fix is for this if any?
1985 Fiero GT
Report this Post10-24-2025 11:02 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Vent on my non AC Fiero does heat up, it doesn't have as much airflow when on hot as when on cold because of the bleed off to the windshield and floor, but it does definitely send hot air out the vents.
Only picture I could find
It's hard to see, I edited it to show the locations of some things, red is the heater core, solid yellow line is when the lower slider is set to hot, all the fan air goes through the heater core before going to the rest of the ventilation system, the yellow dotted line is it when it's on cold, all the fans air bypasses the heater core and goes to the rest of the system. The vent mode should definitely have heat, and that's how it works on all 80s gm cars I've been in. Vent is just the position, the visible vents that aim at your face, HTR is the floor vents and defrost is the windshield vent.
[This message has been edited by 1985 Fiero GT (edited 10-24-2025).]
88Fingers
Report this Post10-24-2025 11:30 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for this information. Appreciate it!
jelly2m8
Total ratings: 242
Report this Post10-25-2025 01:29 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've always gotten heat out of the Vent's in both AC equipped and non AC Fiero's is your car AC or not, you mention Sliders, so I assume a non-AC car
[This message has been edited by jelly2m8 (edited 10-25-2025).]
88Fingers
Report this Post10-25-2025 06:46 AM Click Here to See the Profile for 88FingersSend a Private Message to 88FingersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is a Non AC car
