been out for a few cruises in the last days... the one before today , i started noticing a pulsing type rotational feel and sort of a knocking sound coming from the front end when turning to the left (30-45 mph on back roads). first faint , but today it became very pronounced to the point of starting to shimmy the wheel a bit and i took it easy on the way home. the car isnt pulling , it doesnt exibit this when braking in a straight line to stop. i just pulled the wheel , the lugs were tight , no visible cracks on the rotor. , the pads have an ok amount of meat on them and dont seem to have been overheated. im thinking hub bearing since it seems to happen when pressure is on the spindle in a turn. does that sound right? the ball joints look a bit older, but the car went down the road great , no wandering or anything like that...
also . ive seen videos of what seems to be the rotor and hub structure as one. is this the way it is? if i buy a rotor/ hub off rock auto does it come ready to go with bearings and all? ive also seen full hub assemblies that look like the rears but say they are for the front which accept seperate rotors. can both these configurations be used? or should i need to stay with the hub/rotor combo
[This message has been edited by domer94 (edited 10-02-2025).]
