  MAP function when disconnected 86 GT
MAP function when disconnected 86 GT by Superm1952
Started on: 10-01-2025 06:26 PM
Replies: 4 (85 views)
Last post by: Patrick on 10-02-2025 12:47 PM
Superm1952
Report this Post10-01-2025 06:26 PM Click Here to See the Profile for Superm1952Send a Private Message to Superm1952Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a high idle situation. With that said I have done a lot of reading etc. I see in more than a few instances that people disconnect the MAP to see if it changes the idle. I also read elsewhere that if you disconnect the MAP that the engine will shut off. In my situation the engine is at 2500 RPM and when I disconnect the MAP it shuts down immediately! Is this right or does this point to a possible MAP problem. New plugs, NEW IAC, .49 volts at TPS, installed new TPS, There are alot of things I can try according to these forums so off I will go but the real question is it normal for the MAP when disconnected to kill the engine. It is an old MAP. Thanks Skip in Fl.
Total ratings: 463
Report this Post10-01-2025 07:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the 2.8, nine times out of ten, it's a cracked EGR tube which causes a high idle. The "jacket" on the tube often hides the crack.
Cover the end of your throttle body with the palm of your hand while the engine is running. If the engine doesn't stall immediately, you have a vacuum leak (which may or may not be the EGR tube).
[This message has been edited by Patrick (edited 10-01-2025).]
Mike in Sydney
Report this Post10-02-2025 12:53 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, check the vacuum lines and connectors. The lines are plastic and the connectors are rubber. Chances are they are more than 35 years old and they get brittle with age and the heat from the engine bay.
Superm1952
Report this Post10-02-2025 07:30 AM Click Here to See the Profile for Superm1952Send a Private Message to Superm1952Edit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, Will do that this morning. I didn't want to get into the meat of this .......since I was thinking I would get feedback to do my research on the forum. Anyhow since you were great in responding I will say that PO removed and blocked off the EGR. I am still questioning the MAP removal when the car is running for my own knowledge. Some articles say it still runs but there is a change in idle and other articles say it should die immediately since the ECM has no idea what to do and shuts the engine down. Have you ever tried this on yours? Thanks Skip
Total ratings: 463
Report this Post10-02-2025 12:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...PO removed and blocked off the EGR.
Well, that opens up another can of worms (with a potential lean condition)... but I still suspect you have a vacuum leak somewhere, even if it's not the (removed) EGR tube.
There's also a chance that the PO (who's obviously altered the factory setup) has messed around with the idle stop screw. It's not an idle adjustment screw. Is the factory cap still over the head of the screw, or is it missing?
I have several Fieros, and when I was troubleshooting my '84 duke Here, electrically disconnecting the MAP sensor resulted in the engine running with a default richer setting. However, I seem to recall that disconnecting the MAP sensor on my Formula resulted in a non-running engine.
Skip, if your MAP sensor is bad, it should've set a code. Have you checked for stored codes?
[This message has been edited by Patrick (edited 10-02-2025).]
