  Stumbling upon Acceleration (wierd symptoms) 3800SC
Stumbling upon Acceleration (wierd symptoms) 3800SC by RotrexFiero
Started on: 09-29-2025 06:47 PM
Replies: 10 (123 views)
Last post by: RotrexFiero on 10-13-2025 12:53 PM
RotrexFiero
Report this Post09-29-2025 06:47 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a pretty stock 3800SC has been running great for years, no issues.
Suddenly on way home it would stumble upon acceleration, over 3000K as it was going into boost.
No codes, except I did get on the third ride, a P0300 (i think) which was multi-cylinder misfire.
First, thought it was bad gas, maybe poor octane, so I added some octane booster. No change.
Except from that mentioned above, no other codes. Idles well. Starts right up.
Fuel pressure good, 50psi, and holds after engine is off (no injector leaks). I can hear the fuel pump working. I did change the fuel filter.
Also, I installed new spark plugs, though the old ones were slightly worn they looked fine. Again no change.
I did install a new radio, have not had a radio in a while. Noted when I switch my engine coolant fan on I get a loud pop through the speakers which I thought was odd (and annoying). So I checked the battery grounds, re-did them. No change.
This seemed to appear around when I installed the radio, but a radio can be causing this?
At a loss, I thought it could be a MAP sensor, but everything is connected. Vacuum is normal, but I checked those lines, appeared good.
Any ideas?
[This message has been edited by RotrexFiero (edited 09-29-2025).]
Report this Post09-29-2025 07:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My engine PCM sent a 0300 code a couple of times . The first time it was a bit of water in the gas but after some driving that passed . In the most recent case it was bad ground connection to the coil pack or a burned out coil. Replaced all the coils, put a new ground cable there direct to -12V and the stumble was gone. First check for good ground connection to the coil mounting plate as that could be it, but the coil packs do burn out. Coils detach with a 5.5mm bolt that is hard to find so don't lose them!
[This message has been edited by Dennis LaGrua (edited 09-29-2025).]
jelly2m8
Total ratings: 242
Report this Post09-30-2025 04:02 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Plug wires
[This message has been edited by jelly2m8 (edited 09-30-2025).]
RotrexFiero
Report this Post09-30-2025 06:18 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ordered new coil packs....I guess those are pretty old by now.
So, the consensus is something electrical.
Question: Why am I getting feedback through my radio? It appears when the alternator kicks on, like when there is a high draw on current. I can see the blip in my voltage gauge. Shouldn't the battery absorb, or stabilize any surges? Again, is that a ground issue.
Yes, I am looking at new plug wires, but these are in good shape from a visual inspection.
[This message has been edited by RotrexFiero (edited 09-30-2025).]
jelly2m8
Total ratings: 242
Report this Post09-30-2025 01:27 PM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put the plug wires on first before you waste money on coils. All of your symptoms are classical boosted engine faulty plug wires, visually ok or not.
Doggo
Report this Post09-30-2025 02:20 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
test
Report this Post09-30-2025 06:21 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good guesses that the problem is in the ignition. Can't disagree with that but a small amount of water in the gas from long term storage will also set the P0300 random misfire code. Ask me how I know? If it were an ignition wire would that not just set a code for the affected cylinder? Judging from my last experience, I'll still go with my guess on a coilpack and wait until the solution proves me wrong.
RotrexFiero
Report this Post10-09-2025 09:36 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, I ordered a new coil pack, and within only a few minutes I had them installed.
Dennis you are a genius, or some kind of Fiero savant.
So, it fixed the problem.
I am now worried that maybe the ignition module that is underneath the coil pack should also be replaced.
What is the life expectancy of these modules?
Report this Post10-11-2025 04:21 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad that you got it fixed.Thanks for the good words but am hardly a genius. Just using my own experience in trying to help. For some strange reason the coilpacks on the 3800 engines seem to be a repetitive problem. Might be location close to heat and/or weather exposure. As for the big module itself, I believe that if it goes out the engine will die but there is always a possibility of intermittent operation. It might set a code but only if completely dead.
Always keep a spare ICM just in case as no one can really say how long the ignition module will last. If you buy a spare I would recommend using a name brand like AC Delco, Delphi, Wells or Standard. They are expensive.
Last tip. If you decide to test the coilpacks by measuring the resistance of the primary and secondary windings, they are might read within spec at room temperature but when heated in the engine compartment they can fail to produce a solid spark. This is why I replace in set of three.
[This message has been edited by Dennis LaGrua (edited 10-11-2025).]
Report this Post10-11-2025 04:22 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
RotrexFiero
Report this Post10-13-2025 12:53 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm seeing the ignition module for around $50.....knowing what I know about electronics is "when they go, they go", and these were probably the original coil packs. So, it would be good to swap in a new one.
