  3400 vs 3500 (w/ VVT) questions
3400 vs 3500 (w/ VVT) questions by Kameirocco
Started on: 09-08-2025 01:55 AM
Replies: 9 (124 views)
Last post by: Raydar on 09-15-2025 11:29 AM
Kameirocco
Report this Post09-08-2025 01:55 AM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Running into a bit of a wall here and trying to find a good way out.. My friends, i need some help!
I bought a wrecked 2011 impala with a 3500... didn't place that it was the more complex VVT version.
That version never came with a manual transmission, so the ECU can't be programmed without the automatic.
I was told to grab an 06 G6 ECU as it has the potential to be programmed, but wouldn't be as simple as just taking out the auto transmission from the PCM and may require additional custom tuning...
This yes, was my fault as i didn't do the research on all of this before hand... but now i'm trying to find a way forward.
As much money as i've dumped into this already, instead of enduring more headaches and even more cash, i may be looking at going the more simple route and dumping this engine and going to the more tried and true swap.
I'd be looking at picking up a late 90's early 00's car with a running 3400... questions on all of this stuff below!
3500 question...
1) Has anyone here swapped an LZE with a manual transmission? (or any VVT 3500 variant)
3400 questions - i can't seem to find some answers to the questions on the threads i've seen.
For this swap, i know i would need an ECU tuned to take out the misc crap... as i'm unfamiliar with this, i have some specific questions.
1) as the VSS i believe is a different set on the 3400 vs the fiero... anyone that tunes it with HPTuners can swap the VSS reading to match what the fiero is putting out, right?
2) is there someone here or someone here that knows someone that can do a basic (non performance) tune, basically to make it just run?
3) is there any other got'chas for the others who have done this swap previously?
Total ratings: 461
Report this Post09-08-2025 02:43 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
3500 question...
I don't know for sure about the VVT variant, but perhaps one or more of these threads may be relevant.
[This message has been edited by Patrick (edited 09-08-2025).]
Total ratings: 199
Report this Post09-08-2025 10:08 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 3500 and 3400 are amazing engines in my opinion. There's a lot of talk about that motor on the V6/60 forums. I ran across this thread and happened to have the tab already opened... maybe it will help: https://www.60degreev6.com/...-lze-engine-vvt-lock
Total ratings: 460
Report this Post09-08-2025 11:10 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3.9 VVT LZ9 engine was available in the G6, with a manual trans, starting in ~2006(?). You might be able to run that PCM - or tune - with a few minor variations, to accommodate the .4 liter difference. I was looking at doing that swap, but decided to go in a different direction. Still may, in the future.
I used to have a G6 with the LZE (automatic). I always thought that the LZE or LZ9 would make a Fiero "walk and talk".
For programming options, contact gmtuners.com He goes by "Sinister Performance" or (on this forum - although he's seldom here) Darth Fiero.
[This message has been edited by Raydar (edited 09-08-2025).]
Total ratings: 236
Report this Post09-14-2025 08:03 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The person who suggested teh G6 ECU to you did it for exactly this reason:
The Pontiac G6 was available with LZ9 3900 and F40 six speed manual transmission in 2006 and 2007.
It's not exactly as simple as "can't"
Kameirocco
Report this Post09-14-2025 07:05 PM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mis-spoke there- i should have said not as simple - in speaking with Sinister, the earlier 3x00 swaps are known and easy to program. But this would take a good bit of work to get going with this specific swap.
Yep, that's who i've been speaking to - we had some plans, but was going to get way too expensive way too quick unfortunately - really really nice guy and really knowledge, but since this is an unknown, he said we could get it running, but may require additional tunes, which would require me getting an hptuners box and payign for each tune, which i'd be more than happy with, but i'm on a much lighter budget than that would allow.
Report this Post09-14-2025 08:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have the complete HP Tuning Suite here and and it allows you to include or exclude many different items on the engine that interface with the PCM. . There is probably good info on getting the VVT feature to work with a manual on the HP Tuners Forum but the easier way would be to just swap the entire powertrain in.
ericjon262
Report this Post09-15-2025 03:46 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
There's also the option of using a standalone ECU like an MS3. page 90 of the MS3 pro ultimate manual describes how to setup for a GEN IV V8, and the VVT 3500/3900 use the same trigger arrangement.
ericjon262
Report this Post09-15-2025 04:03 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Member since Jan 2010
1. a 3400 PCM will look for the VSS to be directly input to the PCM, the PCM then outputs a 4000 PPM signal that can be converted to run the speedometer. I'm not sure the stock fiero VSS outputs a signal that's compatible with the 3400 PCM.
2. for a stock engine, the bulk of what will need to be done is disabling VATS, setting the trans type to manual (yes there is a flag for it in the PCM) and adjusting the throttle follower settings to prevent the car from stalling when coming to a stop, it should be fairly straightforward.
3a.the alternator will hit the decklid with a stock accessory drive, there are a few ways of low mounting the alternator, some guys mount it where the AC compressor goes, I made my own mount and tensioner arrangement to low mount it.
My alternator bracket
here's a LZx low mount alternator
3b. you're going to need a neutral balance flywheel, from a 88+ 60V6 application. Fidanza makes (made?) a billet aluminum flywheel that works as well.
3c. if you're running the stock PCM, you can't swap timing covers because you will need the 24x sensor thats goes behind the 3400 balancer.
3d. if you low mount the alternator and relocate the coil pack, you can install a front valve cover on the back, which makes oil changes way easier/cleaner.
Total ratings: 460
Report this Post09-15-2025 11:29 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
FWIW, some people have been deleting VVT, using cam spacers (since the VVT cam has larger journals), and swapping in an LX9 (or that generation) performance cam.
WOT-tech has the spacers and the cams (made by Comp, although they may be an exclusive to WOT, since they are not listed on Comp's site.)
An alternative is to use an LNJ 3400 cam. The LNJ was specific to the '08 Equinox (and its clones, I would suppose). It has the same larger journals as the VVT cam. It's not a performance grind, however. Since it's not on a single billet, I'm not sure if it can be reground. I would guess no. But it's only a guess. There is also supposedly a Melling timing set available for that engine/cam.
[This message has been edited by Raydar (edited 09-15-2025).]
