| quote | Originally posted by richard in nc:
are you sure its not a bad ball joint or something and the tire is rubbing? |
Could be, but im not getting a popping when I wedge a bar under the tire. And the ball joint would have to entirely fall out to scrape against the rim because I have 17 inch rims. Im trying to think of what other part could come loose and rub due to loose ball joints. Everything is rather also attatched to the knuckle and would move with the rotor or isnt close enough.
I swung by the junkyard and their fiero still had a spindle and knuckle. Im a little dumbfounded that they charged me an extra $7 for the rusted out rotor and bearing as if I was going to reuse them. At least they had one though because im starting to assume someone in my shoes with a stripped spindle is gonna have to have a machine shop weld and tap it.
