  What exactly does ALDL Factory Mode Do?
What exactly does ALDL Factory Mode Do? by Nickcull11
Started on: 09-06-2025 12:55 AM
Replies: 1 (56 views)
Last post by: jelly2m8 on 09-06-2025 01:32 AM
Nickcull11
Report this Post09-06-2025 12:55 AM Click Here to See the Profile for Nickcull11Send a Private Message to Nickcull11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
This is for a 1987 GT 2.8L
I have been chasing an idle issue and recently got Paul Romskys ALDL kit. The car runs okay in normal mode with a slight stumble, especially when warm and shifting into gear. I plan to replace the Vacuum lines
When the car is in ALDL mode, it is difficult to start driving and experiences bad idle issues and stalling.
When the car is in "Factory Mode" all issues seem to go away and idle is flawless.
I'd imagine that the ECU is ignoring some sensors and not trying to chase a vacuum leak, or ignoring a failing sensor?
Can someone please provide more info on factory mode?
jelly2m8
Total ratings: 242
Report this Post09-06-2025 01:32 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
It will be hard to do, in ALDL mode the ECM will lock the timing to base timing, I'm surprised it's even drivable. It's diagnostics mode meaning the vehicle is running on base variables and ment to have the engine run at idle so that the readings can be compared to factory ' base' settings.
[This message has been edited by jelly2m8 (edited 09-06-2025).]
