  parking brake handle boot 87 gt
parking brake handle boot 87 gt by domer94
Started on: 08-31-2025 08:59 PM
Replies: 6 (86 views)
Last post by: 82-T/A [At Work] on 09-02-2025 07:50 AM
domer94
Report this Post08-31-2025 08:59 PM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
tackled all the brake cables today , replaced both rear callipers / pads / hoses/ rotors. everything went pretty OK... was nice weather to wrench with the garage door open. will bleed and adjust tomorrow.
now , silly question ... i went to replace the leather handle boot with the new one from fiero store and i cant figure out how its supposed to sit in the trim opening or how it attaches! seems stupid , but no way i tried looked correct. does somebody have the quick and dirty advice? i tried searching with different work combos etc etc. that trim opening has a couple of tabs on the inboard side un the bottom , but it doesnt seem like the metal base frame of the boot would go under those...
strange
Total ratings: 460
Report this Post08-31-2025 10:18 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
strange
If I remember correctly, those two tabs go through a couple of slots in the base.
[EDIT] Turns out my memory is excellent. I found an image online that shows the slots.
CLICK FOR FULL SIZE
[This message has been edited by Patrick (edited 08-31-2025).]
domer94
Report this Post08-31-2025 11:56 PM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the reply. this forum has been great... ive been into many cars over the years and joined many forums.. this one has to be one of the top.
looks like the fiero store replacement doesnt have those slots, but i get the picture now. maybe ill cut some in or see how if fits just over the metal frame.
Total ratings: 460
Report this Post09-01-2025 03:03 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, it's by far mostly a good group. Stay out of the Politics & Religion section and your experience here will be just fine.
Total ratings: 198
Report this Post09-01-2025 08:35 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store one does not have those slots, but I simply took the original and put it up next to it, and then cut slots in the new one where it lined up.
Unfortunately though, the design of the Fiero panel itself isn't all that great, and I haven't seen any Fieros where the two prongs in the panel actuually go into it. Most times, the whole thing just drops back and you can see in there. I'm almost wondering if it wouldn't be a good idea to bend the metal brackets so that it pushes that side up a bit. Just a thought...
Kitskaboodle
Report this Post09-01-2025 09:36 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm, I wonder if Matt Myer or Russ88Ttop sells replacement boots??
Kit
Total ratings: 198
Report this Post09-02-2025 07:50 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
RW Upholstery also sells one... and it has the slots...
https://rwupholstery.com/e-brake-boots
