  Stuck bolt in control arm
Stuck bolt in control arm by Gizmo0816
Started on: 08-31-2025 03:27 PM
Replies: 6 (68 views)
Last post by: Gizmo0816 on 09-01-2025 03:36 PM
Gizmo0816
Report this Post08-31-2025 03:27 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
We got the engine and trans out, but this bolt is giving us a hard time. Its free spinning, but we think it's stuck in the bushing. We tried prying, lots of pb blaster, an air hammer, and heat. I'm wondering if anybody has any tips or tricks for this sort of scenario.
Cutting is gonna be an absolute last resort, cause she has to come off the frame.
Gizmo0816
Report this Post08-31-2025 04:05 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
And if anybody possibly knows where to find a frame for an 88 that'd be wonderful news. This one can be repaired, but I'd rather replace it. Its not in great shape.
Vintage-Nut
Report this Post08-31-2025 04:24 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 'pushed' stuck bolts out with a clamp.....
Put a deep socket over the bolt head and then clamp between the socket and the end of the bolt.
If you're lucky...
Gizmo0816
Report this Post08-31-2025 04:48 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you're lucky...
Will do, gonna have to wait til another day tho. Sprayed a lot more about blaster on and called it quits for today.
Report this Post08-31-2025 05:44 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had one like that. I ended is clamping the cradle vertical, then using a bar on a jack stand and then to the bolt that needed to come out. Taped everything in place to keep the bar from bouncing then when to town on it with a 2lb mini-sledge. Victory!
Stingray92
Report this Post08-31-2025 07:49 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a similar experience, sounds like the bolt has seized to the sleeve of the bushing. In my case I "carefully" used a hack saw to cut through the bolt.
Patience, perseverance, and pain staking work but it has been done.
Gizmo0816
Report this Post09-01-2025 03:36 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like that idea.
