  2.8 v6 remote oil filter
2.8 v6 remote oil filter by domer94
Started on: 08-25-2025 10:35 AM
Replies: 6 (100 views)
Last post by: Dennis LaGrua on 08-30-2025 03:40 PM
domer94
Report this Post08-25-2025 10:35 AM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
did the oil yesterday for the first time... needless to say there was a lot of WTF going on.... has anybody installled a remote filter kit on these cars? looks like one can mount s filter below the vapor cannister area on the trunk bulkhead. nothing came up pn a search
thanks
Spadesluck
Report this Post08-25-2025 12:00 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a remote oil filter when I did a 4.9 swap. There are multiple locations you can use, just do whatever makes sense to you.
domer94
Report this Post08-25-2025 01:14 PM Click Here to See the Profile for domer94Send a Private Message to domer94Edit/Delete MessageReply w/QuoteDirect Link to This Post
so i saw one kit on ebay.... the engine side of the system has the hoses coming out what looks to be flat against the block. would that be a problem with routing? that whole area looked like a beach after a tanker spill. i need to do some serious degreasing and power washing
Report this Post08-25-2025 02:55 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Dennis LaGrua (edited 08-26-2025).]
Report this Post08-25-2025 02:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
I always found oil filter replacements on Fieros to be pretty easy. To change the oil you must go underneath anyway so if you're already there it's just a matter of unscrewing the oil filter and screwing another one back on. .
Total ratings: 460
Report this Post08-25-2025 03:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had also considered a remote mounted oil filter years ago when I first got into Fieros, due to the angle the oil filters sit on these engines. However, I soon learned that it's not difficult to change the oil filters without making a big mess. I even pre-fill the new filters (about 75% full) and don't have any problem with spillage.
Make sure the oil you're finding all over the side/bottom of your engine isn't actually leaking past a rock-hard non-sealing O-ring on the base of the distributor. The distributor sits in a high pressure oil gallery, and oil leaking past a degraded O-ring at this location is not uncommon. The oil then runs down the outside of the engine and makes a mess below.
Report this Post08-30-2025 03:40 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Solution: Unscrew oil filter until you can move it a bit by hand then stop. Now place a small plastic bag over the filter and unscrew it /. The filter stays in the bag. Then tie it closed. Works every time and your hands stay clean as well. This was a tip from Joe (olejoedad)
[This message has been edited by Dennis LaGrua (edited 09-02-2025).]
