I have experienced a totally stuck distributor but on a Cadillac 4.9L engine. I was going to replace the old distributor with a new one but that old distributor was stuck solid. Tried using penetrating oil and tapping the base but that didn't work. I finally got out a big pipe wrench and grabbed the distributor with it. A few times rocking the stuck distributor back and forth with the wrench and it pulled out easily. When you remove a distributor be sure to mark the position of the rotor with reference to the housing beforehand and take a picture of it. Then when you reinstall you'll be close to the timing there was there.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 08-24-2025).]
