  Pop up headlights not coming up
Pop up headlights not coming up by Josh86gt
Started on: 08-20-2025 09:30 PM
Replies: 8 (112 views)
Last post by: Mickey_Moose on 08-22-2025 01:20 PM
Josh86gt
Report this Post08-20-2025 09:30 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started to thread like this a while ago but it has been months and I have lost it I've already replaced the headlight switch and made sure both the relays were working I have to hold my headlight switch right on the halfway spot for the motors to come up if I flick it all the way on and they won't move does anyone know what I could do to fix this I've just recently replaced one of the motors
Total ratings: 460
Report this Post08-20-2025 09:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you Search for it?
Josh86gt
Report this Post08-20-2025 09:57 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried but I think I may have accidentally wiped it out from my emails and I've never been able to get the search function in the forums to work on my phone
Total ratings: 460
Report this Post08-20-2025 10:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, did you see your thread when you clicked on my link?
Josh86gt
Report this Post08-20-2025 10:12 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh I'm sorry I didn't the that was a link
Total ratings: 460
Report this Post08-21-2025 12:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't use a phone to access PFF, so I'm just curious... don't hyperlinks show up differently than regular text in a forum post?
Josh86gt
Report this Post08-21-2025 12:32 AM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I don't know if I didn't let the page load completely or if I'm just a little stupid but I didn't notice that the text was yellow sorry about that
Report this Post08-22-2025 02:22 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 86 Fieros have the Gen 1 headlight system that is trouble prone. Problem could be the control module. If that is the issue no new ones are available but one can be made using a DPDT relay. The gen 1 headlight motors also have internal limit switches that could malfunction and a very flaky gear mechanism that uses internal inserts that deteriorate.
Mickey_Moose
Total ratings: 144
Report this Post08-22-2025 01:20 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time to pull out a meter and the wiring diagram and measure some voltages in and out of the switch and isolation relay.
Since you say you replaced a bunch of parts, it could be simply an issue in the wiring. Download a copy of the factory service manual (I gave you the link in one of your other threads). They have a step by step procedure in them for troubleshooting the headlight system.
Lesson learned: test first and then replace parts - not the other way around.
