  AC question
AC question by cam-a-lot
Started on: 08-16-2025 10:39 AM
Replies: 19 (238 views)
Last post by: RWDPLZ on 08-27-2025 02:19 PM
cam-a-lot
Total ratings: 97
Report this Post08-16-2025 10:39 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
Recently had my AC charged, R134 and seems to be working. 3800 SC motor
Works fine when I start the car. But after running 10-15 min, the AC cuts out intermittently and won't work for a few minutes. Then it starts working again
Could this be too much refrigerant? Or more likely too little? The guy who topped it up only had a tank and didn't accurately weigh the refrigerant
I don't think it is leaking, since it works great next day when engine is cold
Will try to measure low and high side with engine running and AC on. Where should I be with pressure at summer temps (around 26-30 C?)
Total ratings: 198
Report this Post08-16-2025 11:18 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cam-a-lot:
Hello
Do you have a set of A/C hoses? The kind that has the dual gauges and cables for connecting to both the high and low side at the same time? They generally have an indicator on them that should tell you where the pressure should be.
A lot of these places do a half-ass job... (not saying this is the case, but it's a common problem). What should happen is all the Freon that's already in there, should be pulled out. You then put a vacuum motor on both the high and low (using the gauge set I talked about), and it should be able to maintain a constant vacuum of -5 mercury (or ~-5 PSI). With the valve closed to the pump (and the pump turned off), the system should be able to maintain that -5 PSI. If it cannot... then you have a leak somewhere, which would typically be one of the valve seals.
Unfortunately, because you're connecting to both the low and high side valves, you can't actually TEST to see if those valves are even good... these valves themselves actually have a little plastic O-ring as well, and should be changed out too. When you drain entirely a system, they should also change out the expansion tube, which is located in the front of the Fiero... and if I'm being honest, the dryer (the steel cyl in the front compartment) should also be changed out. This has dessicant in it, and if it's allowed to be exposed to the open air (especially if you live by the coast or live in Florida), it's going to absorb water from the ambient temperature. It's supposed to pull out all the water in the lines.
THEN... when all this is done... you should run a vacuum and add the correct amount of PAG oil through the high side vacuum port. This is a good video to explain how it's done:
https://www.youtube.com/watch?v=uqu8Q_p91oY
... and then... seal it back up again and pull a vacuum again. At that point, you recharge with new freon... making sure you shake the R134a cans really well. Some with oil need to be turned upside down, while others can be upright if they don't come with oil).
Anyway, to answer your question... it could be that your low-pressure switch is seeking a lack of pressure, and is temporarily shutting off the compressor. This can also make it really hard to actually fill. In some cars, I've had to take the low-pressure switch connector, and complete the circuit with a paper clip into the connector... that way the compressor keeps moving, and you can correctly add freon. Otherwise you're adding too much pressure before the compressor and then it's forcing the freon into the other side of the line that might be filled with air that came in. This is one of the main reasons why a vacuum should always be done.
It sucks, but if you feel like doing it yourself... expect to pay $200 for every tool you could possibly need (vacuum pump, a good set of gauges and hoses), and then all the O-rings, a new dryer, and a new expansion tube for the Fiero should run you about ~$60 shipped. And then you can literally just buy cans of freon.
It's so much more satisfying when you do it yourself... it's actually really easy once you've done it a couple of times...
Report this Post08-16-2025 02:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was told by a retired mechanic to evacuate the A/C system before recharging to 32 in.Hg that is equivalent to a negative pressure of 15psi. Then monitor if the systems holds for 2 hours. A vacuum pressure of 5inHg = 2.4558psi seems too low. That might work but I believe 32 in Hg may be better. I'll check out my gauge sets later to confirm.
cam-a-lot
Total ratings: 97
Report this Post08-16-2025 05:19 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
system was vacuumed properly. Orifice tube and accumulator dryer was also changed. My question is , is there any chance that there is too much or too little R134A to cause the system to stop working when it gets warmed up?
Total ratings: 198
Report this Post08-16-2025 08:52 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... too little Freon will cause the compressor to cycle because the low-pressure switch will cause the clutch to disengage until pressure equalizes and builds back up. I said that at the end of my long post.
cam-a-lot
Total ratings: 97
Report this Post08-17-2025 04:44 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, thanks. I do have a high pressure/low pressure gauge that I will hook up to it and turn on the AC. Need to figure out what my pressures "should" be at current ambient temperatures I guess, then see if I should add some more R134
cam-a-lot
Total ratings: 97
Report this Post08-17-2025 10:38 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
cam-a-lot
Member since Oct 2010
I connected pressure gauge. Turned the engine on , AC on max
low pressure reads as 110 PSI and high pressure reads as 105 PSI??
How is this possible? Air inside the car was blowing cold. Could this mean I have too much refrigerant and the compressor cuts out because pressure is too high, instead of too low?
Also, on the high side, to the right of the port (toward the brake booster) the fitting actually was warm to the touch, not like the rest of the orifice tube area which was cold. So the fitting on the high pressure side was actually warm
so this is weird
[This message has been edited by cam-a-lot (edited 08-17-2025).]
cam-a-lot
Total ratings: 97
Report this Post08-19-2025 06:54 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could it be I have a blockage in the system? I did change the orifice tube. Is it possible to have put in the orifice tube the wrong way (backwards?)
RWDPLZ
Total ratings: 305
Report this Post08-19-2025 11:32 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since we're not sure how much refrigerant is in the system, compare the pressure to a static pressure chart with the system off for a few hours. This will tell us if it's over or undercharged. 110psi on both gauges at an ambient temp of 80F for example would be highly over-charged. Total R-134A capacity in a Fiero should be about 2.25lbs
The same pressure on the high and low side means the system was just turned on and isn't running yet, or the compressor isn't running or bad. Is the clutch at the compressor cycling on and off at all? You can disconnect ad short the terminals on the accumulator mounted cycling switch to force the compressor on, and see what the gauges read then.
It's technically possible to install the orifice tube backwards, but unlikely. Should look like this installed:
Here's a video with examples of different readings and failure scenarios:
[This message has been edited by RWDPLZ (edited 08-19-2025).]
cam-a-lot
Total ratings: 97
Report this Post08-19-2025 07:59 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply
Here is the weird part. When I took the photo of the gauges, the car was running AC, was blowing cold. So compressor was running and working
I will check the pressure with the engine cold and off and report back. Thank you
cam-a-lot
Total ratings: 97
Report this Post08-22-2025 09:32 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hooked up system to proper AC evacuation machine. Removed refrigerant. Left it on vacuum for a while No leaks detected. Replaced orifice tube again. Looked very oily, some dirt on it even though it is almost new
AC started working as I was charging, I put in 1 KG of R134A
Then after a few minutes of running, the compressor stopped . tried jumping the low pressure switch with a paper clip, AC compressor stayed off.
Turned off the car. After 10 minutes, drove away, AC is working again. Intermittently
Could it be I have a faulty low pressure switch? or high pressure switch? Car has 3800SC and has sensor bung in the AC line. I think that is for high pressure
Any suggestions on how I can check if this sensors are working properly?
Next step may be to change the compressor? It is a 3800 compressor.
Really frustrating....
Report this Post08-22-2025 11:41 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bung in the A/C line is for a pressure switch that the PCM uses for compressor control.
Has your PCM been programmed and wiring harness built for PCM control?
If they have, you need to bypass the low pressure cutoff switch on the dessicator bottle in the front compartment.
cam-a-lot
Total ratings: 97
Report this Post08-22-2025 10:25 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I need to double check, as the PCM was programmed when the car had no AC. So I am not sure. So basically "IF" the PCM is programmed to work with the bung in the AC line, then I do not need the switch on the accumulator/dryer up front?
D B Cooper
Total ratings: 54
Report this Post08-22-2025 10:53 PM Click Here to See the Profile for D B CooperSend a Private Message to D B CooperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine has had a slow leak for decades. I just umm, responsibly recycle whatever is left in the system, and then add 2 cans of R134 through the low side port. Presto !
Report this Post08-23-2025 04:24 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There should be a high side pressure switch on the high side (smaller) A/C line. Should be located in the engine compartment. That sensor provides the PCM an input to control the compressor cycle. I believe that sensor/high side switch is all that the 3800 A/C system needs for PCM control. The gauge readings will tell the story when operating and show fill amount in a static condition. As a secondary check (when operating) you can measure temperatures at the ducts.
If you are concerned about leaks you could add leak detector and then scan the lines with a black light. Any leak will glow and be noticeable. Can you confirm that Ester oil was added to the system when it was changed to R-134a? I believe an empty Fiero system uses 8 oz.
Report this Post08-23-2025 07:47 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is correct.
Just jumper the low pressure switch plug to complete the circuit, or remove the plug and connect the wires.
cam-a-lot
Total ratings: 97
Report this Post08-23-2025 09:31 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, I really appreciate the advice
Report this Post08-24-2025 11:28 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Always glad to help, if possible.
cam-a-lot
Total ratings: 97
Report this Post08-27-2025 08:33 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guys
as I am continuing to troubleshoot my AC issue, I was thinking of changing the sensor in my AC line in the rear (bung in my AC line to 3800 compressor)
Right now I have refrigerant in my system. When removing the old sensor, will my refrigerant leak out? Not sure if the valve is located on the bung itself or on the sensor. The sensor itself looks to have a little "pin" on it- I assume this is there to depress a schraeder valve or something like that in the bung? So (If my assumption is correct), I do not need to remove the R134 to change this sensor?
Will also check wiring to the sensor
Regarding the low pressure switch up front, I will follow Joe's advice, though it probably is not doing anything anyway, since I do not have a Fiero ECM or a Fiero compressor, so I don't think this sensor is actually doing anything?
RWDPLZ
Total ratings: 305
Report this Post08-27-2025 02:19 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
It all depends on how the person that did the engine swap did things. There SHOULD be a schrader valve on the line's port where the 3800's 3 pin switch is plugged in. The cycling switch in the front compartment SHOULD have been bypassed, and not used at all, and in fact should not have been installed on the accumulator and hooked up at all. Whoever did the wiring should be able to explain how they did it.
