  Backfiring when accelerating
Backfiring when accelerating by ViperRedFiero
Started on: 08-02-2025 07:06 PM
Replies: 9 (169 views)
Last post by: Patrick on 08-04-2025 01:49 PM
ViperRedFiero
Report this Post08-02-2025 07:06 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I have an 86 Fiero v6 auto and I need help figuring out a backfiring issue.
So basically the car starts and idles fine but when I head out on the road and try to accelerate it backfires like crazy. If I keep the rpms low when accelerating it’s fine but if I get on it at all it backfires then I’ll come to a stop and put it in park and it idles perfectly and revs just fine.
New parts
Spark plugs, wires, distributor cap, fuel injectors, 02 sensor, map sensor.
It doesn’t have any lights on and it hasn’t thrown any codes so I’m pretty confused. Any help is appreciated thanks
Total ratings: 461
Report this Post08-02-2025 07:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you insure that the wide timing mark on the balancer actually lines up with TDC of cylinder #1? (The outer ring of the harmonic balancer can eventually slip, thus throwing off the timing marks.)
And triple check that the spark plug wires are going to the correct cylinders.
Report this Post08-02-2025 08:04 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was the proper timing procedure followed to a T?
ViperRedFiero
Report this Post08-02-2025 09:03 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I was super careful with the spark plug wires and car revs up perfectly in park so I think im good there.
How would I know if the harmonic balancer slipped?
I followed the procedure for the distributor timing pretty carefully but the backfiring problem got way worse after I adjusted it but the car also seems to run better than it did before so I was hoping it wasn’t related.
Would backfiring be caused by timing being too advanced?
IMSA GT
Total ratings: 250
Report this Post08-02-2025 09:19 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a drawing where the factory damper notch is located in relation to the mounting hub notch.
This is when the balancer slips. Notice how far the notch has slipped compared to the drawing of the stock TDC mark?
[This message has been edited by IMSA GT (edited 08-02-2025).]
Total ratings: 461
Report this Post08-03-2025 12:19 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take out #1 spark plug, stick something like a plastic straw into the hole down to the top of the piston, and then turn over the engine by hand to find TDC. If the balancer hasn't slipped, the wide timing mark on the balancer will be lined up with 0° on the timing scale.
CLICK FOR FULL SIZE
Heh heh... that's my photo of my '86 GT from 2008, although the image has been rotated and cropped.
Originally posted by Patrick Here:
Finally got a harmonic balancer to replace the one which had “spun” on my GT. Here’s a picture of what I saw after I took the crank pulley off. Notice where the main timing mark and keyway are.
Now compare the relationship of the timing mark and keyway with this image of a good balancer.
Had a heck of a time finding a long enough metric bolt at various hardware stores to use to pull the replacement harmonic balancer back on!
Report this Post08-03-2025 08:43 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you letting the car get up to operating temperature (above 180 degrees)? If not, then you won't get several potential check engine light codes.
Have you checked fuel pressure? If it is low, it will idle fine, but go really lean with any type of load and cause misfires and backfires.
Have you performed a compression check? It will let you know if you have any weak cylinders and valves not sealing, which can cause misfires/backfires.
Have you checked the exhaust for any cracks or leaks? Allowing oxygen into a hot ehaust with unburnt fuel will also cause backfires. Misfires do this, as well as cracks in the exhaust.
As others mentioned, it could also be timing.
ViperRedFiero
Report this Post08-03-2025 09:24 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help. I’ll try and check all those things this week.
Yes I’ve let it warm up before driving it and I’ve had it out on some cruises around town and its fine as long as I don’t get on it.
I’m still confused on one thing does the fact that it will rev up to around 5000 rpms while in park rule out things like timing issues and low compression and exhaust leaks or could those still be the culprit despite this?
Also the car doesn’t seem to lose power or misfire when it backfires.
Thanks.
Report this Post08-04-2025 07:03 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Revving while parked is one of the easiest things for an engine to do. It takes very little power and fuel. Revving to 5000 rpm while pulling the Fiero along at speed takes a lot more power and fuel, which will bring any issues with ignition and fueling to light.
Total ratings: 461
Report this Post08-04-2025 01:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I strongly suspect a dyno would tell you otherwise.
