I believe that specifications like rim width, backspace and offset also need to be considered
To further elaborate on that, and cut to the chase, it appears that Volkswagen (new) Beetle wheels are perfect (IMHO) for 84-87 Fieros, unless you want to go nuts.
17x7 or 17x8, 35 mm offset. Those will work on either end, will not hit anything, will look good (like not stick out too far), and can be rotated if you choose the same tires for all four.
Of course, if you want staggered, you might have to shop a bit.
Others may differ, depending upon preference.
