Fiero K swap is underway but im having a lot of trouble with bleeding the clutch system. right now im running a Miata master cylinder with an RSX slave on the RSX tranny. every time I try to pump the peddle, the reservoir wont drain. ive tried doing the whole opening the bleeder, pushing the clutch in, closing the bleeder then repeat about a dozen times. Ive tried using a brake bleeder, ive tried using a syringe to fill the slave from the bleeder. I went as far as bench bleeding the master and it still wont work.
Am I missing something? I had trouble with this with the stock clutch system as well. I know since the clutch system is so large on these cars it can be difficult.
thanks.
James Bird
Certified Idiot
