  Car Dies - Any suggestions?
Car Dies - Any suggestions? by Wacko1Jacko12
Started on: 07-11-2025 07:11 PM
Replies: 3 (47 views)
Last post by: Dennis LaGrua on 07-11-2025 08:24 PM
Wacko1Jacko12
Report this Post07-11-2025 07:11 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Fiero with the 2.8L V6 engine. When I start the car, it idles normally for about five minutes, but then the RPMs drop and the engine stalls. If I keep my foot on the accelerator for about a minute after starting, it will eventually settle into a normal idle. However, after driving for around 10 minutes, when I put the car in park, it dies again. Any suggestions?
cartercarbaficionado
Report this Post07-11-2025 07:22 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
iac,also your fuel tank vent shluld really be fixed first
Vintage-Nut
Report this Post07-11-2025 07:50 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Incorrect V6 Idle Troubleshooting List
Total ratings: 328
Report this Post07-11-2025 08:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Beginning to tackle the problem, first measure the fuel pressure. Does it show 40-43 PSI. ? If so then move on to the ignition. Using a spark tester at the coil-does it show a steady spark. ? Are the plugs, wires, distributor cap, rotor all in good shape.
Also highly recommend that you purchase the Fiero Store scan tool. By supplying live data, that may help you pinpoint the problem in minutes
