  Need Advice: Open Nozzle on Gas Tank
Need Advice: Open Nozzle on Gas Tank by Wacko1Jacko12
Started on: 07-10-2025 10:19 PM
Replies: 9 (145 views)
Last post by: Wacko1Jacko12 on 07-11-2025 06:57 PM
Wacko1Jacko12
Report this Post07-10-2025 10:19 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
I have a Fiero Formula V6. The previous owner removed most of the emissions wiring, and everything has been plugged off—except for one thing. I recently noticed an open nozzle on the gas tank. Should this be capped off, or is it supposed to be left open? I think maybe this was connected to the evap canister?
Mike in Sydney
Report this Post07-11-2025 01:22 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Wacko1Jacko12:
Hi everyone,
There are 3 connections to the fuel tank other than the large fill and vent hoses: A fuel feed, a fuel return, and the vapour cannister line. This should be connected to the vapour cannister. The fuel feed, a fuel return, and the vapour cannister line are connected to the steel pipes that come from the fuel level sending gauge in the top of the fuel tank.
Total ratings: 260
Report this Post07-11-2025 06:53 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is the vent line and it will be venting flammable gas vapors as the fuel in the tank heats up. Under the right conditions liquid fuel can come out the vent line as well.
It is supposed to be attached to the expansion tank in the passenger rear wheel well and attached ot the outside of the upper frame rail.
The 87/88 expansion was done to allow a larger gas tank and more fuel in the tank with the expansion of vapors in the small expansion tank. At a bare minimim, I would run a hose from that barb back to the expansion tank.
The expansion tank should be attached to the charcoal canister, to help elimnate the gas vapor smell.
Jeffh110
Report this Post07-11-2025 09:25 AM Click Here to See the Profile for Jeffh110Send a Private Message to Jeffh110Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have been fighting installing this damn hose for at least 4 hours after changing the fuel pump... it is my nemesis. At least I know it won't come back off.
Mike in Sydney
Report this Post07-11-2025 09:29 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently changed the fuel pump on my car. I cheated by spaying silicone on the outside of the pipe and inside the hose. It slipped on easily after that.
Vintage-Nut
Report this Post07-11-2025 09:36 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Fuel System
Wacko1Jacko12
Report this Post07-11-2025 11:00 AM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for all the information, I plan to reconnect this line back to the fuel tank expansion tank eventually. In the meantime, could leaving this nozzle open cause any other issues? Specifically, would it affect the fuel pressure or overall system performance?
Total ratings: 260
Report this Post07-11-2025 11:16 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is venting flammable fuel vapors.
Worst case those vapors find an ignition source and ignite.
Total ratings: 466
Report this Post07-11-2025 02:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing much...
Wacko1Jacko12
Report this Post07-11-2025 06:57 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Nothing much...
Good call haha… 😆
