  Gen 1 Headlights.
Gen 1 Headlights. by Cobra_Ranch_Garage
Started on: 07-10-2025 02:30 PM
Replies: 6 (94 views)
Last post by: Dennis LaGrua on 07-11-2025 03:05 PM
Cobra_Ranch_Garage
Report this Post07-10-2025 02:30 PM Click Here to See the Profile for Cobra_Ranch_GarageSend a Private Message to Cobra_Ranch_GarageEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt the headlight motors on my '86 GT. I was getting a clicking on the drivers side when closed. After opening them up it was obvious they needed a rebuild. Rebuilt, cleaned up and cleaned up brushes and electrical parts. They worked great, for about 1 1/2 years. Then I came out and the drivers side, same one that gave me problems before, wouldn't open. The knob on top was melted. The right side still worked and wasn't hot. I disconnected the power to both.
This is where I need help. Should I do the $500. after shipping, Ebay Gen 2 upgrade, buy a rebuilt one from Ebay for $225., or...... I can't even find a Fiero at the 5 local pick-a-part places and you can't buy a new motor. Are there any other option or sources, how to's, to do a conversion cheaper? I've searched here and elsewhere and can't find an answer. Thanks.
rbell2915
Report this Post07-10-2025 04:04 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
3rd Gen Firebirds are more common, you can just those headlight motors. Hell, you can probably even use the 4th Gen Fbody motors too.
Vintage-Nut
Report this Post07-10-2025 09:35 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gen 2 motors start at $60 to $100 on RockAuto
PONTIAC>1988>FIERO>2.8L 173cid V6>Body & Lamp Assembly
https://www.rockauto.com/en...,headlamp+motor,1412
I don't know about the Gen 1 to Gen 2 upgrade....
https://www.fierosearch.com...=DoSearch&datesort=D
[This message has been edited by Vintage-Nut (edited 07-10-2025).]
Mike in Sydney
Report this Post07-11-2025 01:40 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't use the Gen 2 motors without doing the Gen 1 to Gen 2 headlight system upgrade. I've done it on all 3 of my '86 Fieros and it's well worth the effort and cost. They are quicker and quieter.
Look around or contact Larry Hubert on the forum and see if you can get the front headlight harness from an '87 or '88 car, including the control module. Larry may even have used '87 or '88 headlight motors but you can get replacements from Rock Auto, Summit Racing, or online thru eBay. There are kits that include wiring and modules to allow you to use the existing harness but I would recommend a complete harness swap. (BTW, if you go with the complete swap, take off the hood. It makes the job so much simpler.)
The module is the weak point in the Gen 2 system but you can find replacements. I used one from a C4 Corvette when mine failed. You can open them up and replace the failed component on the circuit board but I found it cheaper and quicker to just replace the module. Now that I've retired, I may open the old module up and repair it.
The FAQs & How To section has good instructions with pictures. (https://www.fiero.nl/forum/Forum9/HTML/000002.html).
Total ratings: 328
Report this Post07-11-2025 10:06 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously the Gen2 headlight system is more reliable and if needed easier to fix. I own Fieros with both systems. They are not daily drivers and since I only use my Fieros for shows, cruise nights and occasional Sunday drives I didn't see the need to upgrade everything . Founds a new Gen 1 motor years back and did one headlight motor repair on my 85 . It may be a long time before I have to mess with those again, maybe never.
The point is that its probably best, before undertaking on a repair or replacement job on a Gen 1 system, to decide how your Fiero is used. On the other hand if your Gen 1 system is original its a good idea to repair or upgrade. If stuck the Gen 1 motors can overheat and cause a fire.
Vintage-Nut
Report this Post07-11-2025 01:21 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Burning Gen 1 Headlight Motor on Fire
https://www.youtube.com/watch?v=2hEax-qFUuY
Total ratings: 328
Report this Post07-11-2025 03:05 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess that has happened but the rating of the fuse may have something to do with it. GM incorporated a momentary circuit breaker in those GEN 1 motors but a sizable jam might cause those breakers to repeatedly cycle and still allow enough current to allow the motors to overheat. The issue is that there is always power to the motors waiting to be switched on. IMO, the best preventative solution may be to put a safety switch on the white power lead.
There is a ton of 84-86 Fieros out there and the headlight motor fires are uncommon.
