  Distributor timing
Distributor timing by ViperRedFiero
Started on: 07-08-2025 10:17 PM
Replies: 4 (92 views)
Last post by: 1985 Fiero GT on 07-10-2025 01:49 AM
ViperRedFiero
Report this Post07-08-2025 10:17 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I’m relatively new to dealing with distributors and need some help timing my 86 Fiero gt auto.
So basically I moved the distributor around until the car would run and then I marked the notch on the harmonic balancer and the 10 degree mark on the little timing bracket thing. Then I disabled the ecm and started the car and adjusted the distributor until the two marks were lined up.
The car runs good now but backfires when accelerating hard which it did not do even before I tried to set the distributor timing.
I’m not really sure what to do now so if anyone has any advice or tips on distributor timing I would appreciate it.
The car also backfires at idle when it’s warmed up. No clue if this is related or not
Total ratings: 466
Report this Post07-09-2025 03:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read my post Here... and then ask any questions you might still have.
Vintage-Nut
Report this Post07-09-2025 08:06 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or read the Georgia Fiero Club step-by-step "How to Set Ignition Timing on a V6 Fiero"
https://www.gafiero.org/tips/timing.shtml
ViperRedFiero
Report this Post07-09-2025 11:47 PM Click Here to See the Profile for ViperRedFieroSend a Private Message to ViperRedFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I appreciate the help but I still have one question is the backfiring most likely related to the timing problem or is it a separate issue
1985 Fiero GT
Report this Post07-10-2025 01:49 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It could be related, it could be something different, once the timing is correct, you'll see if it's fixed or not, if not then there's more diagnosis.
