  passinger window
passinger window by itzikbns
Started on: 07-07-2025 06:56 AM
Replies: 3 (87 views)
Last post by: Vintage-Nut on 07-07-2025 02:23 PM
itzikbns
Report this Post07-07-2025 06:56 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
passinger window worked well but when I tried lowering it today it went down an inch or two and stopped. it goes up back OK, it sound like the stopege is mechanical, I am not sure, please see the attached video, now I have an issue, I can't disassemble the window since it needs to be in the lower poison to do so. any idea?
[This message has been edited by itzikbns (edited 07-07-2025).]
richard in nc
Report this Post07-07-2025 09:10 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
you need to pull off the door panel and look for problems.you might need to clean out all the hardened grease and regrease with lithium.
itzikbns
Report this Post07-07-2025 10:43 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, but it something I would very much like to avoid, it's a ferrari 308 replica, the external panels are highly modified
Vintage-Nut
Report this Post07-07-2025 02:23 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
richard in nc
Remove the inner door panel, NOT the external door skin.
How to remove inner door panels, with pics
https://www.fiero.nl/forum/Forum9/HTML/000020.html
Rodney's Note about Power Window Issues:
Rodney Dickman:
Many things contribute to slow electric windows. All the electrical connections (starting at the battery) degrade over time, corrode etc. If the dew wipes are hard that can make them go slower. Wiring connections degrade over time. Switches get dirty. The tracks get full of dirt and the grease turns into putty. One can take everything apart and clean and relube everything.
any idea?
Don't use the passenger window...?
[This message has been edited by Vintage-Nut (edited 07-07-2025).]
