  Swapping out a 2.5 for a 3800 supercharged
Swapping out a 2.5 for a 3800 supercharged by mike01
Started on: 07-05-2025 04:46 PM
Replies: 1 (31 views)
Last post by: cartercarbaficionado on 07-05-2025 09:39 PM
mike01
Report this Post07-05-2025 04:46 PM Click Here to See the Profile for mike01Send a Private Message to mike01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 84 SE with an original 2.5L engine with a stock manual transmission. I was given a 1999 Buick Regal with a 3800 supercharged engine with an automatic transmission. I'm a competent mechanic and wondering what issues I should expect during the engine swap. I'm wanting to stay with the manual transmission setup. Will the original transmission mount to the 3800 engine (even if temporary)? Are the engine cradles interchangeable?
Report this Post07-05-2025 09:39 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes the transmission will bolt up to the engine. cradles do not interchange
theres alot of swap information but the 84s are a bit weird but i find much easier to deal with (as they use a 70s style harness or full size harness running power through the solenoid) so i would use the ecu harness from the other car to relocate the main connection away from the exhaust
