  Automatic not shifting above 2nd gear
Automatic not shifting above 2nd gear by LQQKS88
Started on: 07-04-2025 09:31 AM
Replies: 5 (68 views)
Last post by: Dennis LaGrua on 07-07-2025 06:25 PM
LQQKS88
Report this Post07-04-2025 09:31 AM Click Here to See the Profile for LQQKS88Send a Private Message to LQQKS88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 1988 Formula automatic... It is not shifting above 2nd gear. It runs high RPMs but never shifts into 3rd. Sometimes if I stop then speed ahead it will shift fine but not as of my recent ride around town just never got out of 2nd??
Total ratings: 328
Report this Post07-04-2025 04:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the transmission fluid level . If that doesn't work try shifting through the gears manually. Any change??
Are you sure that the transmission is not shifting into third or that the torque converter is not locking up. ? It is common that the torque converter clutch solenoid on these transmissions fail. If that is the case the engine will rev higher and sound like it isn't in top gear. If it is the TCC clutch solenoid that part can be replaced without dropping the transmission.
LQQKS88
Report this Post07-07-2025 03:38 PM Click Here to See the Profile for LQQKS88Send a Private Message to LQQKS88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for your reply I appreciate it we have checked the transmission fluid in the transmission fluid is fine, I've tried driving it using both the first and second gear manual on the shifter of my automatic and it like I said when it goes into second it doesn't jump into third just get a High Rev RPM
Total ratings: 466
Report this Post07-07-2025 04:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When's the last time the filter inside the transmission was replaced?
And has the TV cable ever been adjusted?
I don't know if either of these questions actually has any bearing on the symptom you've mentioned, but figured I'd mention them just in case.
LQQKS88
Report this Post07-07-2025 05:40 PM Click Here to See the Profile for LQQKS88Send a Private Message to LQQKS88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello this was new to me last year had not been driven in sometime before purchase it was in a storage and on display at an antique shop/storage so my guess is no to the above lol.
I have it going to the garage in a week or so as we are not really sure what we are even looking for or how to adjust ect. Praying that is all it is
Total ratings: 328
Report this Post07-07-2025 06:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Years back I did experience slipping shifts with an automatic. I dropped the pan changed the filter put all new fluid in and it worked. Trans shifting was normal again.
trans fluid can go bad. Worth a try
