  3800SC Swap - Alternator options and not charging
3800SC Swap - Alternator options and not charging by GodSend
Started on: 06-27-2025 08:54 PM
Replies: 4 (92 views)
Last post by: olejoedad on 07-02-2025 07:30 AM
GodSend
Report this Post06-27-2025 08:54 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings Gents,
First off, Kudos to James L Brown for helping me out over facebook over the last year. Ive been bugging the sh*t out of him and I thought I would give the poor dude a break and post to the gurus here.
History : 1988 Fiero GT, Pulled the V6 a few years ago and have been swapping in a 3800SC from a 98 Buick Regal every since. Getrag trans, all mounts from FieroRog. Wiring harness was pulled from a junkyard fiero with a 3800NA swap, Was in an accident so im assuming it ran fine (or well enough to hit the road) PCM was purchased from James with a basic tune for my car. Car has never been on the road. Its up on jack stands right now. It starts and idlles. IM working on the exhaust right now, then its off for an alignment and we are ready to go.
Issue : Alt does not charge. Alt is a 11127N from a 2005-2008 Grand Prix. It's NOT the alternator that came with the engine OR the harness. Charge light on center gauge cluster does NOT light up with key in ACC (or during crank).
Things to know : The harness had a plug for a different alternator that I left behind, so I spliced in the pigtail from the 11127N. There were two wires on my harness engine. One Red and one Orange. There are two wires on my alts pigtail, one red and one green(ish). Originally upon James' advice, I hooked Red to Red, and left the other wire(s) disconnected. In this configuration I confirmed continuity from red wire (the only one hooked up to the pigtail) and it goes back to C500 B3. The large lug on alt runs to one lug on starter. Tonight I decided to hook up the second wire (Orange on harness to green on pigtail), no change. I also swapped the bulb in the cluster with a known good one. No change.
So. Advice? Should I try switching the two wires on the pigtail? Is there anything I can/should check with my multimeter from the alt to C500 to PCM to gauge? I have no reason to believe the alternator itself is bad, and as I understand it the gauge cluster battery indicator bulb is crucial for the system to work. Should it light up with everything disconnected? I would like to start by solving the dash light and work from there.
thanks in advance everyone.
Total ratings: 207
Report this Post06-28-2025 10:28 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The alternator requires a 12 volt battery and a 12 volt ignition source to function.
If the alternator is NOT under computer control....
If the bulb on the CHARGE light in the dash is burned out, the alternator will not see the 12 volt ignition source and will not function.
If the alternator IS under computer control, the circuit is different. I can supply that info as well.
Your first task would be to determine if the CHARGE bulb in the dash is good.
[This message has been edited by olejoedad (edited 06-28-2025).]
Total ratings: 328
Report this Post06-28-2025 11:15 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use the GM C130 alternator on a couple of swap applications and this is how mine are hooked up. If you purchase an aftermarket connector it will have 4 wires on it a red blue yellow and white wire. You will use only three
Blue wire -this is battery sensing that goes to the battery terminal on the alternator
Green Wire- This is your 12 Volt ignition source.
Yellow Wire - The connection to the charging light which limits the input to three volts or less. If you have applied twelve votes here you've instantly destroyed the alternator
White wire -not used
This is pretty much what Joe has said. I just added the caveat that if you have mistakenly applied much more than 3 volts to the Yellow (charge light wire) your alternator is now toast,
Jncomutt
Total ratings: 221
Report this Post06-30-2025 09:49 AM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also to add what Joe said, use a conventional bulb for the volt light, not a LED. Some people may find a LED will work fine, but I've had it cause issues in the past.
[This message has been edited by Jncomutt (edited 07-02-2025).]
Total ratings: 207
Report this Post07-02-2025 07:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates?
