That is a good article with one exception. You do need thermal grease under the ignition module or the coils. Ground contact is established through the baseplate and grease can disturb that. The GM manual just says to screw everything together and tighten, no mention of any grease needed but perhaps Fiero Dukes are different. You definately need thermal grease under the V6 ignition module,
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 06-30-2025).]
