  Why does my oil gauge flicker and dance?
Why does my oil gauge flicker and dance? by Kitskaboodle
Started on: 06-26-2025 10:58 AM
Replies: 5 (93 views)
Last post by: Kitskaboodle on 06-27-2025 08:45 AM
Kitskaboodle
Report this Post06-26-2025 10:58 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to tackle this problem:
At idle, my oil pressure gauge flickers & dances. At normal and full oil pressure the dancing pretty much goes away and the needle will stay around 50 psi. Ya, I can live with it but I would like the gauge to behave more properly at idle.
What causes this? I know Fiero’s are famous for flickering gauges so I’m sure some of you are gonna be all over this. 😃 Is this a gauge issue, a grounding issue, a wiring issue or an oil pressure sender issue?
As an fyi I’m talking about my 85 GT and I have upgraded (quite a while back) to the aux. gauge pkg.
sleek fiero
Report this Post06-26-2025 11:21 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would install a manual test gauge and see if you get a smooth reading. If not then I would say you should look farther as in oil pump and or engine bearings. if it does smooth then probably sender is on its way out. sleek
css9450
Total ratings: 87
Report this Post06-26-2025 05:17 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 1988 senders were much more steady and reliable, so sometimes people update their old engines with the 1988-style sender. Requires replacement with the newer-style harness connector.
cliffw
Total ratings: 295
Report this Post06-27-2025 01:41 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Kitskaboodle:
... a grounding issue, a wiring issue ...
I would think both would be a likely culprit.
Total ratings: 260
Report this Post06-27-2025 06:54 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
How smooth is your idle? If RPM is occillating at idle, it will cause the oil pressure to bounce wirth the RPM changes.
Kitskaboodle
Report this Post06-27-2025 08:45 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Idle is relatively smooth. The gauge fluctuates quite a bit at idle. I’m leaning toward a gauge issue. I think the advice above to try another gauge is a good one. I do have another aux. gauge pkg. I could try.
Stay tuned… Kit
