  other cars other than fiero with compatible power door lock mechanicians.
other cars other than fiero with compatible power door lock mechanicians. by richard in nc
Started on: 06-17-2025 07:24 PM
Replies: 8 (137 views)
Last post by: OldGuyinaGT on 06-20-2025 01:42 PM
richard in nc
Report this Post06-17-2025 07:24 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
since i have the door all torn apart is there another car to steal the power lock mechanism from?camaro/firebird?just the mechanism part.there are no junk yard fieros near me.
Total ratings: 328
Report this Post06-17-2025 09:13 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the process of trying to adapt two generic power door lock actuators to my 85 Fiero GT like those on eBay. Might need a custom bracket but it looks like there's plenty of room in the door to locate the actuator. If you wish to add a remote control those are also available.
Check out item 175073821975
[This message has been edited by Dennis LaGrua (edited 06-17-2025).]
richard in nc
Report this Post06-18-2025 01:16 AM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
that sounds great i do want remote doors and engine cover.
BruhMans06
Report this Post06-18-2025 02:49 PM Click Here to See the Profile for BruhMans06Send a Private Message to BruhMans06Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was able to fit some generic $25 Amazon power door locks on my 84. theres plent of space in the door to fit them and also it came with some universal brackets that were easy enough to drill into the metal and mount inside the door. Ive had them in there for almost 2 years now and hey have not failed me yet.
Total ratings: 328
Report this Post06-18-2025 03:37 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The universal door lock kit that I have comes with two long metal brackets. They are not long enough to bridge the opening in the door so I will have to adapt another method. Some installations that I have seen with these universal power door lock openers, mount them directly on the inside of the door while others I have seen put a bracket across the opening and positioned the lock opener somewhat into the door space. The trick is that you need the door lock opener making a straight pull on the lock rod.
OldGuyinaGT
Report this Post06-19-2025 11:42 AM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I replaced my door lock actuators on my '88 GT a couple of months ago. I used these:
https://www.amazon.com/dp/B..._asin_title_0_0&th=1
I removed the brackets they came with, replaced them with the brackets from my originals, and they dropped right in.
Spadesluck
Report this Post06-19-2025 03:18 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are those strong enough to lock and unlock the first time?
Total ratings: 328
Report this Post06-19-2025 08:43 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The power door lock actuators that I bought off ebay seem to pull very well. There was one guy here that put them on his car about two years ago and as far as I know they are still working. They are basically just simple electro-magnets pulling or pushing a plunger.
OldGuyinaGT
Report this Post06-20-2025 01:42 PM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
They work great so far, both operating and sounding much more definite than the originals. Of course, the originals worked very well too, when they were new and everything was clean. I also cleaned and lubed everything inside the door. Bottom line is they're great a couple of months in; for life and durability, check back in about 5 years.
