if the bolts fit thats good BUT you should consider using a
Grade 8 bolt hardness for them to hold up. Grade 8 bolts are expensive because they are made of high grade steel. Check with ARP for the grade or look at the top of the bolt head. Also check the GM part number as they still may be available.
