  Getrag: Length of Gear Selector Shaft: Fiero vs FWD
Getrag: Length of Gear Selector Shaft: Fiero vs FWD by reinhart
Started on: 06-08-2025 05:25 PM
Replies: 7 (100 views)
Last post by: reinhart on 06-15-2025 04:02 AM
reinhart
Report this Post06-08-2025 05:25 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would someone tell me the distance the gear selector shaft sticks out of the case on a Fiero Getrag vs a FWD Getrag? (measuring the distance from the outer edge of the case to the end of the shaft).
I searched the archives and surprisingly couldn't find this info.
Total ratings: 461
Report this Post06-08-2025 09:59 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check Rodney Dickman's web site. He used to sell conversion kits. He had pages of info and instructions posted.
I don't remember seeing that info, exactly. But if it's anywhere, it'll likely be there.
reinhart
Report this Post06-09-2025 12:59 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea I checked everything Rodney has. Nothing about the lengths.
Should be easy to get the Fiero Getrag number for sure. Just need an owner to measure.
cartercarbaficionado
Report this Post06-09-2025 03:01 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
if no one else does i will tommorrow if i dont forget
reinhart
Report this Post06-11-2025 07:50 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Report this Post06-11-2025 09:36 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
crap. i knew i forgot something. let me do that and ill edit this with the measurements
Report this Post06-12-2025 04:03 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
in the relaxed position (neutral) from the case to the top of the nut is just about 2.5 inches tops out at about 2.75 but the spare 2nd fiero is a little taller at 2.95 but it has 3x the mileage and didn't shift properly
reinhart
Report this Post06-15-2025 04:02 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by cartercarbaficionado:
Check your PMs. Thanks!
