  88 Steering Linkage. What's So Special?
88 Steering Linkage. What's So Special? by cmd88
Started on: 06-03-2025 10:33 PM
Replies: 2 (95 views)
Last post by: fieroguru on 06-04-2025 11:45 AM
cmd88
Report this Post06-03-2025 10:33 PM Click Here to See the Profile for cmd88Send a Private Message to cmd88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Having a hard time finding an 88 steering linkage (intermittent shaft). So I ask:
1 - How is it different from older models?
2 - Can I use older linkage on 88?
Thanks!
Vintage-Nut
Report this Post06-04-2025 10:14 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're in need of '88 parts; send member Larry Hubbert a PM....
Total ratings: 260
Report this Post06-04-2025 11:45 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are talking about the steering shaft from the column to the rack, then the 88 ones are shorter and come in 2 versions. One with a universal joint and the other is a rag joint.
