  ECM?
ECM? by rockygt
Started on: 06-02-2025 08:55 PM
Replies: 13 (177 views)
Last post by: Patrick on 06-08-2025 03:35 AM
rockygt
Report this Post06-02-2025 08:55 PM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Howdy yall, I am working on a 85gt stock , Im having trouble running right, this car has not ran in 5 years, i have a clean fuel tank, new pump and filter, and great fuel pressure, oil pump is new and great oil pressure, 1000cca battery new, new starter and wires added ground to block and frame, new distributor, wires and plugs, cylinders pressure checks look good 125-140, the timing is set correctly( did it with the motor out),positive there are no vacumn leaks, egr functioning right, I have had this car 23years and done all my own work, it lacks all peformance put in gear(4speed, cutch good), no engine trouble codes, so here is the kicker i can remove spark plug wires change them around 3 at time and no change in the way it is running, if i pull number 4 wire it dies, no others it just runs as it did, im 66 yo and worked on all my cars my whole life but i gave never seen this, is this the ecm causing this ( coil is new also) any help will be appreciated!!!
Report this Post06-02-2025 09:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check that both fuel injector fuses are good. (Don't just look at them.)
IMSA GT
Total ratings: 250
Report this Post06-02-2025 09:20 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you timed it with the motor out of the car, you may need to re-time it jumpering the ALDL connector. Here is a writeup:
https://gafiero.akroncdnr.com/timing.shtml.html
rockygt
Report this Post06-02-2025 09:31 PM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did reset the timing to the aldl being jumped, 5 yrs ago i put a new cloyes timing gear and chain, the car spun on blocks and trapped me i pushed it off and had surgery to remove 4 bones from my wrist, so it was a year plus before i trided woking on it, recently i pulled the engine to verify everything... it definately has me stimpped
cartercarbaficionado
Report this Post06-02-2025 11:42 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
it could be the ecm but that sounds much more like you have dead plugs or stuck closed intake valves. is this a 4 cylinder or v6? 85 was the first year for the v6.
if it is the v6 sometimes the valve preload is too much and compresses the valve springs before reaching preload which uhh doesnt really help anyone
edit: before someone yells at me i have seen a few 85 gts with a duke still. not sure if they were ordered like that or not but my guess is not.
[This message has been edited by cartercarbaficionado (edited 06-02-2025).]
steve308
Total ratings: 58
Report this Post06-03-2025 09:16 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Have you been able to pull codes?
rockygt
Report this Post06-03-2025 09:58 AM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a v6 2.8l, there are no codes coming up, thank yall
rockygt
Report this Post06-03-2025 10:00 AM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
rockygt
Member since Aug 2018
I did check each cylinder and each cylinder is sparking
Total ratings: 290
Report this Post06-03-2025 10:18 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grab one of these.
https://www.harborfreight.c...gic-probe-63597.html
Backprobe the 6 position connector where the injector harness plugs into the engine harness. Google backprobing to see what it is. With the connectors still plugged together and with the engine running check the pink and the pink black wires. Each should have +12v on them. Next using the probe check the Lt. Blue and Lt. Green wires. Each should show +12v most of the time and should show ground quickly.
If you aren't getting the 12v on the pinks check the fuses.
If you are getting the pulses on only one of the lt blue or lt green wires you might have a wiring problem or a bad ECM.
Report this Post06-05-2025 08:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If any of the obvious circuit checks do not produce anything unusual then it may be time to consider buying a scan tool that will provide live data like O2 sensor and MAP readings. BTW with 123456 engine timing if one cylinder goes down you may or may not hear it.
rockygt
Report this Post06-07-2025 09:20 PM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank everyone for yalls help, the problem is 1 dead injector, 5 firing but no spray....thanls for getting me back on the road real soon!!!!
rockygt
Report this Post06-08-2025 03:00 AM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by phonedawgz:
Grab one of these.
You nailed it sir, the injectors are the problem, the fuse was blown on one bank of the injectors, after testing all of them i only had 2 fireing, and i could not get those to spray with the test kit i have... thank you very much!!!
rockygt
Report this Post06-08-2025 03:06 AM Click Here to See the Profile for rockygtSend a Private Message to rockygtEdit/Delete MessageReply w/QuoteDirect Link to This Post
rockygt
Grab one of these.
Report this Post06-08-2025 03:35 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You nailed it sir, the injectors are the problem, the fuse was blown on one bank of the injectors...
You're welcome.
