| quote | Originally posted by jdv:
[URL=https://www.ebay.com/itm/176409589117?_skw=TTL-232R+%285V%29+chip&itmmeta=01JWSBDRDPVWD6NCQF36PS74AW&hash=item2912d4b57d:g:Z-EAAOSwUoZkuP2e&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1f7s9sPQg%2FKVXIb4cD%2FNyn%2B9Z%2FFXwkcsbaeHowauIPgKkOCl0QJZeJTVUJ2dk md9K%]https://www.ebay.com/itm/17...Cl0QJZeJTVUJ2dkmd9K%[/URL] 2B%2BGin5k0A89qLzEfALIiSgP5U5n6RZSXXZiddCtivF5xhFqTkiwdsDgMduP0EleOcq1y8yxAkFm8MLTk1oR5rURJGOMfBSnrCrL2oja1FZhEytUavcp%2BMqh9GJMx063u2yAxSZkHmXefhqnr99kvK6z4MFhR0RLpRYppwVu1w4nRvkxL6lmdQuWr9213Pyf%2FSxDbog8%2Fb3SWTvcsGqMTAm2sIwaZV9iBXd3%2BsDuiw7Yg%3D%3D%7C tkp%3ABFBMhIe3q-Zl The Rx and tx leads go to the m spot on the aldl and the ground goes to ground. Make sure the jumper is on 5v. Use tunerpro.net . https://www.gearhead-efi.co...0-ECM-Information-24 |
@jdv
I bought the mentioned adapter and also a "12pin to 16pin" adapter and cut the 16pin connector.
on the 12pin plug are 4 cable
yellow to pin K
green to pin M
red to pin G
black to pin A
Based on the thread of Paul Romsky has the ALDL following pins:
Could you confirm that the data stream comes from ALDL pin M? Means 8192baud? Or from pin E, 160baud?
Based on above picture pin E is the data stream. Or i'm wrong?
[This message has been edited by 308Fiero (edited 08-01-2025).]
