| quote | Originally posted by CFiberFiero:
There was another thread but it didn't quite answer my question. Rather than revive it I started a new thread.
As is my seat belts are very tired. They don't like to retract at all and needed coaxing to return home. I imagine I can restore them, but I thought I'd first ask if there was a common upgrade I could do. Also, the stock seatbelts also don't "lock" when pulled quickly like modern seatbelts do (at least mine dont and I couldn't find info on that). Is there anything that might be modern and compatible with the fiero? Having both no airbags and no modern seatbelts is sketch |
For what it's worth... we were able to clean a set of light grey seatbelts in my daughter's 1985 Fiero 2m4 SE, which we bought that had over 200k miles on it. They came out immaculate.. this is them hanging / drying after we cleaned them...
This is the link to the whole process of how we cleaned them:
https://www.fiero.nl/forum/Forum1/HTML/100861.htmlWe also added a little bit of grease to the mechanism so that they would retract back to normal. They work really well right now... there are no issues with them, and they look brand new. As I mentioned, they had over 200k miles on them, and they were disgusting looking, very very dirty. We got the passenger side basically looking like it was brand new (not even a spot anywhere, and no wear whatsoever), while the drivers side looks like it's maybe a year old. There's a little bit of wear where the seat belt consistently would go through the top loop... I'm really overexaggerating it... it basically looks like a new seat belt. You can see in the pictures they are basically gleaming...
Note: I had to zip-tie them when fully extended to keep them from retracting as I let them dry...
EDIT: Not the same thing, but if you're looking to renew your interior as well... I also used RetroBrite on many of the plastics to get it looking "like new." See this thread:
https://www.fiero.nl/forum/Forum1/HTML/100866.htmlAnd an example of what I was able to do with it... (RetroBrite is like $20 bucks):
[This message has been edited by 82-T/A [At Work] (edited 05-15-2025).]
