  brake proportioning valve
brake proportioning valve by GreggDauer
Started on: 05-03-2025 07:39 PM
Replies: 5 (154 views)
Last post by: Brian A on 05-06-2025 10:49 AM
GreggDauer
Report this Post05-03-2025 07:39 PM Click Here to See the Profile for GreggDauerSend a Private Message to GreggDauerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My brake proportioning valve in my 84 is pretty gummed up and I'm having trouble finding a replacement. the only valves I can find say they fit most GM vehicles but look nothing like mine. Does anyone have a part number for one that will work, or do I have to just buy an adjustable one?
Vintage-Nut
Report this Post05-03-2025 09:10 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
1984 Pontiac Fiero VALVE, Hydraulic Brake Combo/Monitoring {a.k.a. Combination Proportional}
GM 10026021 / GM 10036563 which of course were discontinued...
For Informational Purposes Only
That Combination Proportional Valve
https://www.fiero.nl/forum/Forum2/HTML/109173.html
PFF "Proportional Valve" Search
https://www.fierosearch.com...alve&Action=DoSearch
Doggo
Report this Post05-03-2025 10:48 PM Click Here to See the Profile for DoggoSend a Private Message to DoggoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I could ship you the one I just took out of my 85 we replaced it but I’m pretty sure it wasn’t the issue and still works. I’ll send you a PM
donuteater306
Report this Post05-05-2025 12:15 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wasn't able to find one for my 87 either. Do any of you know how to tell if it's working properly?
Report this Post05-05-2025 11:28 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The brake proportioning valve doesn't break too often. If you ask around the there are probably dozens of used units available that could work.
The S10 proportional valve looks like a very close duplicate of the Fieros.
S-10 Brake Proportioning Valve
Brian A
Report this Post05-06-2025 10:49 AM Click Here to See the Profile for Brian ASend a Private Message to Brian AEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by donuteater306:... Do any of you know how to tell if it's working properly?
Seems to me a few threshold brake stops should tell.
In a safe location, drive up to 35 mph and hit brakes to just beyond threshold. Have an observer note which wheel locks. The front brakes should lock and the rears should still be rolling.
Next, repeat except hit the brakes with full leg strength; all 4 wheels should lock.
If the brakes perform this way, the proportioning valve is working correctly.
Experts: Do this sound right? My concern is if the proportioning valve (by design) reduces rear brake pressure so nonlinierly that it would never allow the rear brakes to lock in the second test.
