  High idle while rolling.
High idle while rolling. by Csell2
Started on: 04-28-2025 05:59 PM
Replies: 2 (87 views)
Last post by: phonedawgz on 05-03-2025 12:29 AM
Csell2
Report this Post04-28-2025 05:59 PM Click Here to See the Profile for Csell2Send a Private Message to Csell2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello!
Got a funny issue with my 84 duke 4sp. Start up is fine, drops to correct idle. Get it moving in gear and it's fine upto ~30mph, then the idle kicks up to 1500-2000 and refuses to come back down until the car comes to a complete stop. Speedometer works 100% fine.
Disconnecting the VSS or the panel connector to the speedometer board makes the idle act naturally, but then I got no speedometer!
Thought it was the board itself so I ordered a new used board to compare from TFS and plugged that in, with minor success (worked for half of one drive).
All the connections are clean, and connectors fully plugged in, my only thought from here is that it could be the ECM (someone did replace the original with a 86 3 speed ECM at some point during its life).
Please let me know whatever thoughts you might have!
cartercarbaficionado
Report this Post04-28-2025 07:22 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Csell2:
Hello!
sounds like you figured it out already, the automatic ecm tried to raise idle in what it thinks is drive to keep the transmission crawling
Total ratings: 290
Report this Post05-03-2025 12:29 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rolling idle is programmed to be higher than the stationary idle.
The ECM doesn't know if your clutch is engaged or disengaged. So as a precaution the ECM keeps the idle speed higher so there is less chance of an engine stall between shifts. Most people don't even notice it. But yes, you will notice the ECM drops the idle speed to the warm idle of 1000 rpm at something like 5 mph.
