Due to the fact that I run a boosted engine, there are important extra gauges that Ive added the the dash to monitor critical parameters: Fuel pressure, Vacuum/Boost, and an Air Fuel gauge. Fuel Pressure is important as if it goes too low and the engine goes lean under boost it can blow. Vacuum/boost is IMO equally important as it shows if the supercharger is functioning. Air fuel gauge is also critical as it will show where the mixture is . Again too little fuel under boost and there goes a piston.
All gauges were working well until today where the air fuel gauge pinned to max even with the ignition in the on position. Had a spare changed it and now all is fine. I find it unusual that the digital air fuel gauge burned out. Can't figure out why except that it may have received a voltage spike or it was just cheap Chinese quality. My opinion is that it was a low quality Chinese unit that just burned out. They're bringing over some real garbage from that country. Next replacement if necessary; Stewart Warner like my other gauges. They cost more but never had a problem with that brand.
