  Auto to manual swap clutch safety switch
Auto to manual swap clutch safety switch by mrroy61805
Started on: 04-12-2025 09:44 PM
Replies: 3 (75 views)
Last post by: pmbrunelle on 04-13-2025 11:26 AM
mrroy61805
Report this Post04-12-2025 09:44 PM Click Here to See the Profile for mrroy61805Send a Private Message to mrroy61805Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good afternoon,
First off before I get killed in the comments I did try the search function but for some reason it's not working on my phone.
Now that that's out of the way I have an 88 auto that I'm doing a f23 swap on and I was curious as to how people are bypassing the clutch safety switch since that section of the body harness is not on my auto body harness. I appreciate any help/advice given.
IMSA GT
Total ratings: 250
Report this Post04-12-2025 11:09 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
See this thread. It discusses what you are doing and what you may need.
https://www.fiero.nl/forum/Forum2/HTML/148355.html
Vintage-Nut
Report this Post04-13-2025 11:15 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
EDITED - Auto to F23 transmission
I don't have any experience on the subject but...
Can you connect the safety switch to the automatic park and neutral switches?
To me, do not "bypass" the safety switch!
I found three threads on "Auto to F23"
https://www.fierosearch.com...3%20&Action=DoSearch
[This message has been edited by Vintage-Nut (edited 04-13-2025).]
pmbrunelle
Total ratings: 63
Report this Post04-13-2025 11:26 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The automatic neutral safety switch is located in the engine harness. Doing as you propose would require running two wires to the front, which would be difficult to implement in a clean manner.
To do a more factory-style install, the large starter solenoid wire in the driver’s footwell can be interrupted with the clutch switch, as was done on factory manual transmission cars.
