  Clutch kit compatibility
Clutch kit compatibility by saving_rossi
Started on: 04-11-2025 03:02 PM
Replies: 5 (127 views)
Last post by: 1985 Fiero GT on 04-11-2025 04:49 PM
saving_rossi
Report this Post04-11-2025 03:02 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got a dumb question. I realized I got a clutch kit for an 01 sunfire, which is where I got my transmission from—but the engine I’m putting in (3100 SFI )has 170 hp and I’m not sure this will fit and if it does fit I’m not sure what power this clutch is rated for.
Sun fire was 115 hp and I got the kit from MPACT, 04-159-WS clutch kit
I’m probably just going to return it but if this will magically be compatible. Let me know ❤️
1985 Fiero GT
Report this Post04-11-2025 03:12 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What engine, what transmission, what year?
saving_rossi
Report this Post04-11-2025 03:42 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine is from a 2002 Buick century limited v6 3100 SFI,
Transmission is an F23 5 speed from a 2001 Pontiac sun fire, fiero is a 1985 SE v6.
Filben
Report this Post04-11-2025 03:42 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went through this. The clutch should match your transmission. I messed up and now have a brand new Getrag 5 speed stage 2 clutch kit in a box. It will end up in The Mall soon.
saving_rossi
Report this Post04-11-2025 03:55 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I don’t have to return this? The clutch does match my transmission.
1985 Fiero GT
Report this Post04-11-2025 04:49 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
In this case, the pressure plate must match the transmission, the flywheel the engine, and the clutch disc must match whatever power you are expecting, for the 4 speed, 5 speed, f23, etc. the flywheel is the same, clutch disc is compatible, and the pressure plate makes up for the different Bell housing sizes.
I'm using a spec 3+ clutch and pressure plate from the transmission, flywheel from an 88 Fiero (same as 3100, 3400, 3.4, 2.2 used with f23, etc.) my clutch disc is speced (get it? The brand... Haha) will have plenty of grip. In your case it will work, but i don't know how well a 2.2l clutch disc will hold up to the 3100. In performance or custom applications, often components do not work off the shelf, a clutch might need to be carefully selected or pieced together, it might fit, but it might not last.
