  3100 SFI oil pan notching
3100 SFI oil pan notching by saving_rossi
Started on: 04-07-2025 02:20 AM
Replies: 3 (68 views)
Last post by: saving_rossi on 04-07-2025 01:32 PM
saving_rossi
Report this Post04-07-2025 02:20 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im about to put a 3100 SFI into my fiero, which has v6 mounts on it. I hear that the oil pan needs to be notched and the dog bone needs to be cut—I am wondering if there are any pictures of what this should look like. I haven’t started it yet but I pick the engine up on Tuesday.
How big will these cuts/ notches need to be? What’s the difference here between a notch and a cut? Trying not to screw myself over, and wondering what tools would be best to use to cut/notch correctly. I have a dremel, that’s what I assume would work.
saving_rossi
Report this Post04-07-2025 02:24 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also, for the same swap—I think I will be keeping the alternator in the stock location, and I’ll notch the decklid…how have people gone about making an upper dogbone connection elsewhere? I see engine bay pictures with the stock alternator location and no upper dogbone to be found…thought maybe they are using solid mounts. Not sure where to source those.
1985 Fiero GT
Report this Post04-07-2025 06:08 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the 88 Fiero, the oil pan needs to be notched, 84-7 you notch the engine mount bracket that bolts on the engine, making a triangular area more L shaped, I used an angle grinder that I got from Walmart for $20 cad. I don't know about the dogbone because I'm using the Fiero top end. You can get weld on solid transmission mounts from Rodney, don't know about engine mount.
saving_rossi
Report this Post04-07-2025 01:32 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, appreciate the detailed description I have an angle grinder to borrow.
