  i got two junk engines need help
i got two junk engines need help by saving_rossi
Started on: 04-02-2025 09:33 PM
Replies: 9 (202 views)
Last post by: Dennis LaGrua on 04-09-2025 08:35 PM
saving_rossi
Report this Post04-02-2025 09:33 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was putting an '88 v6 into my fiero for an f23 swap, since I had one on hand. Turns out one of the cylinders has rot that was way worse than I thought it was. It maybe can be bored out and cleaned up, but I can only find 1mm oversized pistons. I don't see any other options anywhere.
I know a 3800 swap is the way to go, but I don't have the extra time to source everything for it right now. I am open to being convinced but I'm on a tight budget. I can put in maybe another 1.5 k at most right now, but i really wasn't planning on that. I still have to get gaskets and a new oil pan. I'm a college student. I was really looking forward to getting this card on the road in the next couple months.
Report this Post04-02-2025 10:06 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the cylinders are scored deeply an overbore may not work. One mm is almost .040" over and new pistons/rings are no longer available in that or a larger size for the 2.8L. For a quick fix I would go with a rebuilt long block. A 3.4L Camaro/Firebird P/R engine long block its an almost bolt in job and will provide a bit more horsepower..
VEGE engines has these engines and you can buy one from Summit Racing Equipment, About a $2400 investment but should provide a headache free install
[This message has been edited by Dennis LaGrua (edited 04-02-2025).]
cartercarbaficionado
Report this Post04-02-2025 11:02 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
how bad you want one? i got 2 options. i send you to a nearby friend in Oregon who wants 100 bucks but you gotta pull it or 2 you come grab my stripped shortblock i got in Washington 250 miles away that is known good but i want 200. if you need a gas tank i got a good one of those there too.
i do have to mention none of those options are 88s. i have the full clutch setup for the short block and he just does complete engines. should work out
[This message has been edited by cartercarbaficionado (edited 04-02-2025).]
Spadesluck
Report this Post04-02-2025 11:44 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am pretty sure there are still stroker kits available if you want to go that route.
Report this Post04-03-2025 10:34 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out ARI Racing Engines. This might be a good option for you. If you have to find a replacement engine, I recommend you go with a minimum of a 3.1 engine. The horsepower is the same as the 2.8, but I swear it has more torque than my 3.4. My 3.1 came from a Lumina APV van. The starter boss is already on the correct side, and there is no need to upgrade injectors or anything else, except to be sure you use a neutrally balanced flywheel or flexplate.
Should you ever want to go to distributorless ignition, the 3.1 *(and 3.4) have ports in the side of the block for crankshaft sensor and knock sensor.
https://engine-parts.com/online-store/
[This message has been edited by fierofool (edited 04-03-2025).]
Report this Post04-03-2025 12:54 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats not a bad option either. some of us have had some pretty cool 3.4s (i really liked that turbo 3.4. destroked and everything but just using the block for the better oiling and stronger sides) borrowed track fieros but ive never driven a 3.1 swap. it would be the most direct swap for his 88 specific 2.8 since its already super close and the dis systems are pretty easy to use if you grab the obd1 engines
either way hes got a few options and if he pms me theres litterally a guy in his town who has a few 2.8s
saving_rossi
Report this Post04-03-2025 03:27 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
$100 sounds pretty good, I found someone in Hillsboro who wants $400 for a pulled complete engine + wiring and ECU out of a Camaro that supposedly was running. According to them it was going to go into a sand rail.
If I had time I’d head up to Washington, that’s where it everything is apparently. But also. This Camaro v6 is plug and play yeah? It’s from an 88 I think.
Report this Post04-03-2025 04:50 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
i dont think the LC1 (camaro 2.8 since no 3.4 on the 88 and prior 3rd gen) fits correctly.. i might be wrong if someone else wants to chime in. it is listed specifically as rwd. the 94-95 Camaro is what you want
edit: i think my pm sent? idk the site kinda wigged out or my internet died again for a few seconds
[This message has been edited by cartercarbaficionado (edited 04-03-2025).]
Vintage-Nut
Report this Post04-03-2025 05:03 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If You Go the "Used" Engine Route:
I highly recommend testing the motor before payment...
The best test is a Leak Down Test; however, I believe not many will put in the effort.
The easier way is checking the compression on each cylinder; low compression readings can indicate issues.
If not, at least as the minimum, rotate the crankshaft...
Report this Post04-09-2025 08:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We only use the leakdown test and it gives very reliable results on cylinder and ring condition. It must be used with an air compressor. It won't detect a bad crank or rod bearing but if you get great cylinder readings the chances are that they are probably good but be sure to look at the entire engine. .
Used 2.8L Fieros are approaching if not being 40 years old. IMO they are worth very little. Sold the ones that we had here for $100 each, and they were low mileage but you cant escape AGE. Even on old low mileage engines, crankshaft , oil pan, manifold , water pump and timing cover leaks are very common.
