  Fuel sending unit
Fuel sending unit by LS4FieroGuy
Started on: 03-29-2025 09:44 PM
Replies: 4 (106 views)
Last post by: LS4FieroGuy on 04-01-2025 08:14 AM
LS4FieroGuy
Report this Post03-29-2025 09:44 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So as most of us know the Fieros fuel pickup doesn't pick up fuel from the bottom of the tank. So my question is can you either make the sending unit pick up fuel all the way from the bottom or is there a way to make it so the fuel level sensor accurately reads?
Joshua Seeger
GodSend
Report this Post03-31-2025 05:55 PM Click Here to See the Profile for GodSendSend a Private Message to GodSendEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can take the sending unit out and use a multimeter to measure as you move the float up and down. There is a fix to cleanup and solder the wirecoil the float touches, but doing so you can get the output to match the expected values. Mine was wildly out and I performed the fix about 10 years ago. Its as accurate as any other car I have driven at this point now.
Although the pictures aren't there, this post sums it up in better detail than my faded memory.
https://www.fiero.nl/forum/Forum2/HTML/092117.html
buddycraigg
Total ratings: 478
Report this Post04-01-2025 12:41 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
what GodSend said.
Stinks that the pictures are no longer there.
cartercarbaficionado
Report this Post04-01-2025 03:13 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the level sender is either a fierostore kit, what the other person sent or what ronald finger did.
any of those will work fine its your choice. personally i dont trust any fuel gauge below half and on gms i dont trust them at all and assume the worst (thanks squarebodys)
LS4FieroGuy
Report this Post04-01-2025 08:14 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome! I appreciate the help guys.
