  common carburetor issues?
common carburetor issues? by kateperry
Started on: 03-29-2025 01:14 PM
Replies: 4 (98 views)
Last post by: Dennis LaGrua on 03-29-2025 05:40 PM
kateperry
Report this Post03-29-2025 01:14 PM Click Here to See the Profile for kateperrySend a Private Message to kateperryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello! i recently purchased a 1984 2m4 and have been looking at it with my friends to try to figure out what’s wrong with it. attached is a video of us spraying starter fluid into the throttle body while attempting to start the car. it cranks and starts, but dies only around half a second later. my mechanic friend says it may be the carbeurator that’s causing me trouble, or the spark plugs. i would love some general troubleshooting methods / common issues with the carbeurator that may be halting it, or any other suggestions on issues, thank you!
kate perry
Report this Post03-29-2025 01:34 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is stock, it will be throttle body injected.
First check would be fuel pump and fuel pressure then injector pulses.
Report this Post03-29-2025 03:11 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by kateperry:
...attached is a video
As you've discovered, videos cannot simply be "attached" to a post here.
Upload your video to YouTube, and then embed it in your post by copying its URL from the browser and pasting this URL between [youtube] and [/youtube] with no spaces.
[This message has been edited by Patrick (edited 03-29-2025).]
Total ratings: 200
Report this Post03-29-2025 03:21 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it starts with starting fluid being sprayed in there, then the ignition and spark plugs are probably OK.
It sounds like it's just not getting fuel. The Fiero is a fuel injected car, and doesn't have a carburetor. First I think it's best to give us a bit more background information. Is this car new to you... and was it non-running when you got it? Or is this something that just happened and it was running fine before?
My first thought is the fuel pump, but I really need more information about the car... (questions above) before we can better diagnose.
Report this Post03-29-2025 05:40 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the fuel pump is original to the car then its most likely bad. There is also a fuel pump relay that could be bad. A quick test. Remove the fuel line from the throttle body. Attach a small 3/8" diam rubber hose. Place the end of the hose in a 1 qt milk carton away from the engine. Turn the ignition key on and leave it on for about 20-30 seconds. Then shut it off. Your should see a small amount of gasoline in the milk jug. If you see NO gasoline then the fuel pump is probably bad.
The fuel pump is replaced by disconnection the hoses, dropping the empty gasoline tank down and replacing the pump inside. Its a process that you will have to look up and learn about.
